97RangerXLT
TRS 25th Anniversary
- Sep 18, 2007
- 4,019
- Fishers, IN
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0
- 2WD / 4WD
- 4WD
- Total Lift
- 2"
- Tire Size
- 31"
Back down at the parents. Another new disposal and a much more pliable ground wire soldered to the stiff one. About a half hour fighting the wires and plumbing and it works fine, no leaks.Went down to visit my parents for Easter. their garbage disposal (original to their house ca 2010) had some serious rust in the grinding chamber and was starting to get clogged up pretty easily, so Dad ordered a new replacement from Amazon back in late January. the replacement was basically an exact new version of what was being removed. So we took the old one out, unhooked the plumbing and then let the disposal down to lay on the cabinet floor to easier access the wiring. the original installers run a flexible conduit to the disposal, and we seriously fought that connector for 2 hours. finally got it out with a small pry bar, the little plastic nut that secured it was glued on. Ok now we are rockin' with Dokken. took another 10 minutes just to fish the wires out of the little pannel as the were tucked up under and the actual feed wires were very stiff. got them out, got them unhooked, first thing I noticed was that the feed wires were pretty heavy gauge wire and very stiff. spent litterally 2.5 hours fighting the ground wire to get it bent and to hold in place to tighten the ground screw around it. the wire kept springing out of the way and we had to keep manipulating it and because it was so thick, it barely went around the ground screw. Finally got that all buttoned up, and it took like 2 minutes to reconnect it to the sink and the drain pipe. plumbing was easy-peasy. ran the water in it, no leaks filled the sink, drained it, no leaks. Dad went and turned the breaker on and nothing worked. ok... Dad went back to the breaker box and the breaker was tripped. reset the breaker, came back in ran the disposal and it was running great, really quiet. I was just getting ready to gather up tools, towels and bucket and out of the corner of my eye I saw a drip of water. by this time dad turned off the disposal. ran some more water, no leaks. turned the disposal on and saw some drips of water coming from the hole where the conduit went in. Well fawk. looks like the shaft seal of the brand new disposal is junk or not installed correctly. So since the disposal was bought in January, we are past returning it. so it is call Insinkerator for warranty replacement or sink another 100 bucks for a new disposal and have it within a day to fix it...
Good thing I am going back down the following weekend...
AJ
Moved on to better things such as a distillery tour and Bourbon tasting at Buffalo Trace Distillery with my dad and sister. The nation's oldest Distillery, since 1786.
Got a pint of Blantons while there.
AJ
