Bill
898
Sacramento, CA
I took it for a drive to Costco to pick up a pizza, and over the last several days I tested how well the A/C would work in 115° heat. The temperature coming out of the vent was between 45° and 52°. OBD 2 states the coolant temperature was around 190° to 195° while the intake was sucking in 134° air over 12 lanes of asphalt on US-50. If I got on the gas it would go up to around 200°.
I also discovered ONE advantage to 115° weather, and that is takeout pizza remains hot on the trip back home.
superj
2,624
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
you don't see many mosquitos in that temp, either
BiggSherm1988
57
Germany
Ford/Ranger
none...yet
not for me
Not today but over the long weekend.
Installed 2 pioneer 8" subs in a sealed box, 1500 watt amp, all new door speakers, 800 watt amp, and some fancy amazon special carbon fiber nock off mud flaps.
The box is just temporary. I had it left over from another vehicle. but the sub amp is mounted to the bottom of the driver side jump seat and the door amp is placed under the passenger side jump seat. once the box is sorted both jump seats will be fully functionable.
James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
4.0L in XLT, 3.0L in B3000
31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
The perfect is the enemy of the good.
Replaced taillight lenses. Both had holes about the size of a quarter at the bottom. They passed it for inspection before I bought it a year ago, but they shouldn't have... and chances are for me they'd fail. Rock Auto ones are cheap and fit and look just great.
Weird thing here where because of 'demic you have 3 mos add'l to get inspection... but... you can still get stopped for bad equipment, and if you do, you get a ticket for that, PLUS a ticket for inspection out of date. In other words not inspected is ok for 3 mos as long as you don't get stopped (can't be a "primary" offense) but it can be a secondary offense if stopped for anything else... not worth the chance.
You can't get an inspection appointment unless you go to a dealer. Otherwise, you are leaving your vehicle in line at a place for, literally, days. Since the price of inspection is so low, they get addressed last after / in between any paying work. Kind of a mess if you ask me. They were doing similar thing with plates/registration last year, if you had a DMV appointment, you could drive with temp plates even if expired.
If you fail inspection you get 15 days to fix stuff or you are up a creek. I don't think there's an extension on that, so, you kind of want to make as sure as you can that you are going to pass it.
superj
2,624
ranger edge
none
none
235s
we had extensions too, and maybe its still ongoing but i get to anxious driving with bad stickers. i just go during work hours when the lines are zero to almost zero at the inspection stations
Bill
898
Sacramento, CA
I've seen quite a few dead insects from the heat. I think the mosquitos stay close to water when it is hot.
lil_Blue_Ford
6,192
Butler, PA, USSA
4.9L
Sounds like 60x100 would solve that problem
At this point I’d be happy with being able to get the 18x28 I have up. Be even better if I could get two more frames for it to get it a little longer and maybe build a lean to off the side. Eventual plan is a 40x80-100 with a loft and basement. I need a backhoe and money though. For both.
snoranger
Professional money waster
ASE Certified Tech
13,678
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
You need to get ready for the trip.
superj
2,624
ranger edge
none
none
235s
They stay in the shade under the taller grass and stuff like that. Mosquitos are part of everyday life here. And we near the water, 1/3 of a mile to the ocean :(
broncc
568
MA, USA
Ford Bronco II
5"
Giving my truck more money than it deserves.
Been driving the bronco entirely too fast through the woods and doing sweet jumps. Hit/landed on something particularly nasty and it pushed the wheel into the fender and crunched it. Just hammered it back straight tonight.
I was just rushing to get it done so no before image. The metal is a little streched inside the fender, but the outside profile is correct. Now I need to find out why I have positive camber on one side and negative on the other...
1990RangerinSK
1,312
Saskatchewan, Canada
View attachment 81851 View attachment 81852
You probably bent something.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Trimmed the fenders and made upper coil retainers. The coil retainers were easier than I anticipated. Some 1/4” thick 2.5x3.5” angle iron with over sized washers to clamp the coil to the coil bucket without having to drill holes in the coil buckets.
Bill
898
Sacramento, CA
I cursed at it because it stalled twice due to the high idle, then dropping to 500 rpm and long term fuel trims that behave like there's a vacuum leak.
And while I'm complaining about this problem again, I'm going to complain about many of the automotive forums. I posted this issue on several forums thinking I would get some reasonable feedback. What did I get? People insisting that this is normal. 1200 rpm is normal when you are coming to a stop, not 3000 rpm. People telling me to clean my injectors, replace seals and gaskets AFTER I mentioned that I replaced these items. If someone wants to be helpful they can start with reading and comprehending the description I posted. Then there were the people who suggested various snake oils and "mechanics in a bottle." Someone suggested filling the intake with Seafoam to clean it. Then there were the people who like gas treatment to absorb water out of the gas tank and clean the injectors or the odd mention of how they used Marvel Mystery Oil and it fixed their idle issues (no, it didn't). There's also quite a few posts on forums with this problem, but they dead end with no resolution posted. People on the internet can be frustrating.
Maybe I didn't get much in the way of good replies because I posted too much technical information.
Anyway, Marvel Mystery Oil is good for breaking down carbon if you let it soak overnight in warm weather. So, it does work for something.
I think I'll go stare at my truck tomorrow and decide which part to randomly swap out and hope it fixes the problem.
