bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
putting the 35 inch snows on the ranger...they still look great.....yokohama I/T do pretty good.. wish falls mastercraft wintermaster were available in 35's....
should probably do some sort of tarpalation roof for the bronco....but i have to go to work.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Gets wet in there.....
And cold. Gotta figure something out 🤔
scotts90ranger
4,475
Dayton Oregon
2.3 Turbo
Drove to work of course, the way I aimed the headlights wasn't working in the heavy rain but was fine on the drive home tonight... just gotta aim the drivers side light a bit left so I can see the line better... and maybe a little up from the next part of the venture home... I stopped at home depot and picked up 6 40 pound bags of water softener salt (save like $.75 a bag when you buy 6...) and put them all in the rear drivers corner of the bed, it sure drove funny... and squatted a fair amount :)
RustyShackleford94
Just some guy
355
IN
Got my new to me wheels and tires on, The 225s make it stop and go much better. Need to find me some center caps. Pics tomorrow when its light out!
scotts90ranger
4,475
Dayton Oregon
2.3 Turbo
wait, you get to see daylight? lucky...
James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
4.0L in XLT, 3.0L in B3000
31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
The perfect is the enemy of the good.
Cleaned headlights, started with 600 grit, then 800, 1200, 1500, 2000, 15 micron, 5 micron, 1 micron, then hand glaze, which probably doesn't make much difference after the fine papers. All wet sand. Probably not "like new" but a lot better than they were. I suspect some hazing may be inside... new ones aren't that expensive, but right now can't afford new parts, still haven't put in all the parts I have. before/after pics:
alwaysFlOoReD
5,135
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
View attachment 69076View attachment 69077
How long did that take per side?
James Morse
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
Well it doesn't take very long, I'd say at the most an hour in total so half hour a side?
There are kits and formulas for it you can buy, I think; I have all grits of papers on hand already because I use them in sharpening planes and chisels for woodworking, and I also use them when I finish alkyd paint onto wood. If you bought them all it would be some dollars.
I just take a little piece maybe a couple inches square, wet it, do both sides, go on to the next. I wipe off the debris after each. I guess the slowest part is going close to the little nibs but no need to go nuts about it. I always go -vertical- up and down with the sanding versus circular, it works better, for this.
Because you are progressing through grits gradually you just need to spend a short time with each. You'll see the debris in the water.
When I get to the last glaze I am going circular but the rest I stay vertical.
There are formulations like PlasticX I think it is but I believe they are actually some kind of solvents anyway I can't vouch for them I didn't use them.
The main thing is if you work with the 600 first pretty well, you will have removed the outer surface haze/discoloration, from then on it's just removing scratches left by the 600 by going successively finer.
Normally all these fine papers are wet-sand papers. The key to the water is it's a lubricant of sorts and importantly it floats sanding debris (and any grit that might detach from the papers, but, normally that doesn't happen) away from the work. I just have a bowl of water, dip the paper in it, and sand gently up and down covering all the surface, wipe with a paper towel, do the other side, and go to the next paper, it's not hard.
I suspect it's not too different than any sanding task where you generally use the coarsest paper you can to start out and then work finer, but the finer grades are to sand out the scratches left by the previous-coarser paper as opposed to really removing much material. When you are done it should feel really smooth to your fingers and it should look better. I confess at the end I rubbed in some Armorall, since they are plastic, but I doubt that actually does much of anything. Good luck and I hope that helps a little, and of course there's always the option to just spring for new lights but I think you can get a big improvement with the sanding.
superj
2,706
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
my dad said bug spray made his yellow lights turn clear again. like off or one of those types of bug sprays
alwaysFlOoReD
5,135
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Yes, the deet, or the other liquid carrying the deet, is a solvent. I looked into that but havent tried it. I had a bottle of mosquito repellent on my dash that had a leak, it definitely acts as a solvent....
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
I’ve used “Off”on my headlights. It works great. I’ll never go through all the trouble of sanding and polishing lights.
scotts90ranger
4,475
Dayton Oregon
2.3 Turbo
When I did mine last weekend I just used some soapy water (was handy...) and some 0000 steel wool which left it pretty good, but I went through the trouble of finding the headlight polishing kit I had so I went to use it and found it missing the 3000 grit paper so I said screw it and just used the polishing compound it came with on the foam pad in the drill, bet I took 15 minutes to do both headlights, sure it's not as smooth and fancy but it's way clearer...
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
12,789
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The down side to those headlight polishing kits is they don’t last more than a year.
The problem is the protective coating that originally came on the headlight lens fails and oxidizes.
The kit removes the failed coating and protects the lens for a little while but you will need to keep up on them from then on.
In the long run, it might be easier and cheaper to just get new housings. Pick your poison.
