17,833
SW Iowa
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
ericbphoto
16,598
Wellford, SC
6"
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
No. I haven't. Aside from being complicated to install, I think I would have a very long, rough learning curve with that in my truck.
Getting enough throw on that to actually operate the clutch on an M5OD transmission sounds like quite a challenge. And operating it smoothly? Wow.
No thanks. My solution is easy.
Have you considered one of those hydro e-brakes like they put in drift cars?
*edit. I now realize this wouldn't really work as well unless you had 3 arms lol. A button is much easier to deal with.
sgtsandman
Aircraft Fuel Tank Diver
12,646
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I refuse to accept a twin stick as anything but a Np203/205 doubler...
Simply adding a high-low lever to a single case isn't actually achieving anything but 2wd low. A twin stick doubler gives you 3 speeds in 4 and 2wd. Which is actually a triple stick if done right...
4wd on and off lever for the 205, hi-low on the 203 lever, and hi-low on the 205 lever.
So you have hi-hi, hi-low, and low-low in both 4x4 and 2x4.
Twin stick also gives you neutral.
sgtsandman
12,646
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
A doubler would make my life much more fun.
They make them. I think I still have a link saved but you’d have to wait until I get home to give you the link.
scotts90ranger
4,368
Dayton Oregon
2.3 Turbo
Got the estimate on the cash payout for my tailgate issue from Yesterday already, it's $100 more than I paid for the Ranger originally... :) I think I can live with that...
ericbphoto
16,598
Wellford, SC
6"
Can’t be spending money on that right now. I actually have a second t-case to make a doubler following the instructions in our tech library. But I doubt I will ever do that. Making the new shaft is a pain, plus it seems to be a weak point.
sgtsandman
12,646
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Did the initial setup and poking around on the Midland GMRS MicroMobile radio. It seems to work as it should testing it with the handhelds and Quad Band Ham radio. I just have to wait for a mount bracket to come in so I can piggy back it off the TYT TH-9800. A better antenna and mount are on order as well. Once that is all in, I’ll temporarily install it into the 2011 until I can scrounge up the cash for a higher end radio for it. The permanent home for the MXT275 will be the 2019 when that happens. Less room to mount radios in these new Rangers compared to the original models.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Anyone made their own over head storage shelf/ radio bracket? I’m thinkin about building one that spans the width of the cab to cary my rifle, then mounting my CB and marine radio under it.
sgtsandman
12,646
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I did not but came close. There is a second layer of sheet metal around the perimeter of the roof that is about 2” wide and a bit of an extension in the middle where an over head console would go in an Explorer. I had to make a spacer out of a 2X4 to fill in the gap between the headliner and the roof to support the CB. The spacer fasted to the extension and the radio bracket to the 2X4. The radio doesn’t move.
I’ve used that same lip to mount a Big Sky rifle rack to the ceiling behind the seats as well.
17,833
SW Iowa
Depending on trim on a first gen you could have a solid steel headliner too. Good for mounting normal console stuff to... probably not great for mounting rifles to.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
I’m picturing a half inch tube frame with sheet metal, that spanned the width of the cab, approximately 10-12” front to back, with a top hinged door that’s lockable and has a shock to hold it open.
sgtsandman
12,646
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I think that will be too deep. At least in front of the seats. Build a cardboard mock up and try it before you build the real deal. Sit in the seats and move around to get things off the floor, the glove box, etc. Also, consider traffic lights. Where do you normally see them in the windshield?
There are a few lights, because of their placement in the intersection, that I have to stop short of the intersection with the windshield visor I have on the truck. Kind of an apples to oranges comparison but an example of things to consider before you make blind spots or something you’ll be smacking your head on.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
I hadn’t thought about that. Very good point and I’ll definitely use the cardboard idea. I’m only 5’6”, so I don’t anticipate any issues with creating blind spots. I’m gonna double check though lol. I’m wanting to make it just big enough to clear a 30-30 or maybe a scoped .22. If it fits an AR too, that’ll be cool. I’ll post pictures and maybe do a build thread when I start building it.
Also, this truck is my hunting truck, I won’t be DD it or driving it in town much.
