I installed a Builtright Industries dash mount in the 2019 because I've gotten tired of having issues with the suction cup mounts for my cell phone and GPS. I got a mount system for both as well as one for the Samsung tablet that will eventually get used for off road driving with the forum members.
I did run into a couple of glitches with the install.
1) Getting the tray to reinstall, I had to remove some plastic from the underlying support structure so the nuts would clear. Either the manufacturer installed the fasteners upside down and didn't clarify that or ran the mount base all the way forward in the tray to avoid the plastic under structure and failed to mention it. I wanted the space between the mount base and the tray to still be available to store stuff. So I had to take extra steps in order to make it work.
2) The bracket arms aren't long enough. I thought that could be a problem but being a first timer in installing a ball mount system, I didn't know for sure. I'll just have to order longer arms so I can drop the devices down some more and block less of the view out the windshield. The tablet mount may require some try and try again in order to get it right.
Other wise the install went fine and looks good. The base works with AMPS format. So that made choosing the arm mount portion easy enough. It also seems to be a pretty solid mount base. I think the plastic center tray will start giving out before the mount base will.
