What Causes This?
helpme
18
Hotlanta
Was parking on a hill( about 10 to 15 degrees). As soon as I switched off the ignition, the brake pedal went hard and the truck began to roll backward. I immediately disengaged the clutch pedal to stop the rolling.
Is this a bad master cylinder, bad brake booster, or vacuum problem elsewhere?
It is an old vehicle, a Vulcan 3.0 with 277K miles on it. The master cylinder was replaced about 2 1/2 years ago.
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Bad Booster?
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Brake booster comes to mind for me as well. That an using the parking when parking and shutting off the truck. Depending engine compression to hold it is an accident waiting to happen.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
One-way valve for the booster. Or the booster itself if the valve is internal.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Loosing vacuum somewhere from the check valve up. I believe on those the check valve is just the piece on the end of the vacuum line that plugs into the booster. But the booster itself could also be leaking somewhere internally.
8,370
+1 to all the above
Pedal gets hard because you are losing the Vacuum assist from the booster as soon and engine is shut off
That shouldn't happen, the booster is so large so it can hold 3 "assisted" pedal pushes in reserve, in case engine should stall while driving, gives driver assisted braking to pull over safely and stop
On the booster there is a check valve, just looks like a 90deg fitting, which it is, but there is a check valve inside it
It just pulls out, the check valve holds vacuum in booster so engine can't use it when its vacuum level changes
But booster could also have a leak in its internal diaphragm
Follow boosters hose over to the engine and pull it off at engine end, you can turn the hose as the 90deg check valve will rotate, so end of hose is closer to fender
Blow into the hose, you shouldn't be able to, that means Check Valve is working
Suck on the hose, that's a vacuum, it should HOLD that vacuum, if you can continue to suck on the hose then booster is leaking internally, you might even hear the leak
Jazzer
457
Indianapolis
Use a turkey baster for those tests, so you don’ t feel weird about it later....
-Jazzer
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
-Jazzer
Ron always wants people to suck on hoses... :rolleyes:
Jazzer
457
Indianapolis
I’ve heard Canadians sometimes call each other “hosers”, is that what thats means? 😱
8,370
Yes, suck on the hose, you hoser, lol
In Canada Hoser means a "loser" and maybe stupid
I prefer to think it came from the Losing Hockey team having to "hose down" the ice so it was smooth for the next game, so the hoser was the loser
But some say it came from someone who siphoned/stole fuel with a hose
But its a Canadian expression, and theives siphon fuel every where not just in Canada
helpme
18
Hotlanta
Thanks guys. That check valve is a $5 part. I thought that it was just a right angle connector. I'll pick one up in the morning.
