I need to replace the muffler on my 2000 Ford Ranger and need to do it on a budget. I've been reading and all the muffler manufacturers recommend that if the old muffler had been welded on you need to replace the pipes that connect to it (tail pipe and connector pipe). Is this due to length issues? IE - if you cut the stock pipe to weld in a new muffler, it will be too short. Or is it that they are worried about rust or something? The length isn't much of an issue because I will be moving my exhaust so it comes out in front of the rear tire instead of at the back of the truck anyway.
So, can I use a new muffler on the old pipes and weld away or do I need new pipes? The tailpipe is solid, only surface rust from the looks of it, lots of metal left and no holes.
