want to weld my d35 spider gears?
4x4junkie89
nor cal
2.9
so i want to permanently weld the spider gears in my d35. people are telling me that you cant weld it cause the gears are cast, so im wondering if anyone knows if they are and how can i do it. since i have manual hubs i can just unlock them for the street, im not worried about the axle cause i plan on doing a solid axle eventually
4.0B2
151
Walls, MS
4.0 v6
did you do a search on this?? idk the answer. but i'm sure it can be done...
Bennybooster
EMT / Paramedic
37
Medford, Oregon.
talk to Nathan, he did it to his and loves it
legoms013
09/2013 OTOTM
26
CA
4.0L V6
Its been done a billion times. The spider gears are not cast. Go for it.
-Nathan-
39
Saskatoon, SK, Canada
HO 5.0 / 7.3 PSD
I did it, no problem.
just burn it in nice and hot.
I would ONLY recommend doing this to a trail rig, and to NEVER use 4x4 with a welded front diff on the street, you will NOT be able to steer.
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
I wanted to do this and everyone told me I wouldn't be able to steer at all when in 4wd.
legoms013
09/2013 OTOTM
26
CA
4.0L V6
Its no different than me running a Lock-Rite. Your turning radius is affected, but its not that big of a deal at all.
-Nathan-
39
HO 5.0 / 7.3 PSD
on the trail, you learn to control your turning with throttle :)
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I have never found my Aussie to hinder my steering at all on the trail. Might be different on a shorter wheelbase rig I suppose.
disciplerocks
53
Evansville, IN
My Aussie hinders mine quite a bit. I'm doing a lot more 3 point turns than I used to.
-Nathan-
39
HO 5.0 / 7.3 PSD
my lockright definitely hindered my steering on the trail on my old rig, however not as much as the welded diff.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
with stockish power its not too bad, you get up around 300hp and you will empty the junkyards of d35 parts if you use the power.
legoms013
09/2013 OTOTM
26
CA
4.0L V6
The turning radius of my supercab already sucked, so the lockrite did make a difference but it was not a shocking difference.
