2.3L ('83-'97) want to run carb and dizzwop setup on 88 ranger block/head in 1990 ranger
stamina
34
Wilmington, NC
4” suspension
265/75/r16
built her in a storage unit
i have a 1988 ranger 2.3 4 cylinder block + head + accessories, and i want to run as close to the latest model carbed versions of the 2.3 engine (2bbl carb whatever) as possible, i want to use an original ford 2.3 aluminum intake made for a carb. which vehicles have the carbs and intakes i need? are there different versions of the carbed intakes? which one should i be looking for? did Ranger 2.3's ever come with a carburetor from factory? (not the 2.0) my block has a distributor/the hole for it, whats the cheapest/easiest way to get spark? Duraspark dizzwop + HEI? i am going to just keep the 1991 4.0 power accessories underhood harness and unplug the engine harness from the two big connectors and leave it be? i am going to run the original accessories and brackets (no a/c) or the later model serp belt brackets (if they fit which i think someone told me they do with a bit of drilling) will a 1988 ranger balancer that has the two pullies on it spin a late model serp belt? or should i just get a later model balancer? i want to keep the in-tank electric pump system, i need to run a lower pressure pump? you guys are the best!
(THE TRUCK IS A 1990 WITH A 4.0 IN IT AND ALL STOCK PARTS)
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
2wd?
esslinger and bopart....
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
