liljoe0985
- Jan 31, 2009
- 0
- Georgia
- Ford
- Engine Size
- 3.slowwwwwwwwwww
bump
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
I just popped in here in the last page and thought I'd give my input on the 78/79 housings. Depending on your intended use, tire size, ride height, etc the case wedges may or may not be good.
I narrowed a 79 housing and kept the radius arm setup. After going through all the work, I found that even after extending the RA's and using 7* c-bushings, I couldn't tuck em up as close to the frame as I had hoped. Looking back I wish I would've gotten an axle with welded wedges so I would have the option to either run RA's or link it. With the cast wedges I'm stuck with a RA setup no matter what.
Just something to think about.
The factory radius arms are acceptable in most cases depending on were they fall on your frame rails (interfering with other pre existing items). I do not recommend extending the stock radius arms, if I remember correctly they are cast steel and should not be welded. I assume you are familiar with how those cast wedges affect your camber? Along with the 7 degree C-wedge bushings Brad is talking about?just making sure that that setup would indeed work for me before i went and bought a whole parts truck...i may look into that 78 f150 more then, gonna give the guy a call tomorrow and ask him a few questions...im set on coils now and it just seems like purchasing a truck for 400-600(the 78 f150 i was talkin bout earlier) with the casted wedgies ready for coils,radius arms i need(which ill extend), and tires and wheels (if for nothin else i could use for mock up) would save me a lil money and time hunting down stuff...not tryin to cut corners or make it any easier just seems if thats the way im goin and if itll work then i can kill 2,3, 4 birds with one stone
And just about the time you get it done, your buddy will build something bigger, case in point:Being to cool kid on the block is not everything its cracked up to be.
86
