Upgrading my 2wd to 4wd. Questions.
atlanta-bmx
Georgia
Ok, So i went down to the nearest junkyark and I found 2 rangers that are 4wd. I want to rip it all off and bolt it to my truck. I have a 2003 Ranger edge 2wd. It's pretty much a 4wd but without the 4wd driveline. My question is: What all do i need to take off, and is will it bolt up straight to mine? Any other advise is strongly suggested.
Thanks guys!
wvfarmboy
03 ranger 4.0
99 ranger 3.0
its been done but a lot of workand expertese be easier to get a 4x4 frame and put your body on it but again a lota work be better just to save up and get a 4x4 ranger
scotts90ranger
4,511
Dayton Oregon
2.3 Turbo
on an edge it is a bolt on, it's not like the TTB/TIB stuff, I havent done it so I don't know all that's needed, sorry
77'cj7
Rapid City, SD
I haven't done it, but you'll need the transmission, transfer case, both driveshafts, the front differential, front axleshafts, front hubs (maybe).
No idea what you would have to do to make the t-case electronics work.
Also, check that the donor truck gear ratio is the same as yours, otherwise you'll need the rear axle too.
atlanta-bmx
Georgia
That's what i was afraid of, swapping transmissions. And the electronic t-case might be a PITA. I appreciate the feedback though, I'm still debating on whether to trade for a 4wd or swap it over. I think trading for one is taking the lead in the decision making.
77'cj7
Rapid City, SD
I would probably go ahead with the swap, but instead of the stock t-case, find a manual shift case from a 93-97 ranger.
Then again, I enjoy taking on major projects with my truck.
ambivolent
southern iowa
3.0l FFV
ive been looking into this because im gonna eventually convert my 2wd to 4x4 you will need to weld in a bracket that holds the front diff in place other than that everything else is bolt on there was a build thread on one of the ranger sites i cant find it right now but if i can find it ill pm you the link
