Forcus
- Sep 18, 2007
- 0
- Sparland, IL
- Ford
Hey guys, starting to put my truck back together with newly painted parts (started the frame off "resto" 6 weeks ago). I am looking for suspension bushings and U-bolts now. Here are my questions:
1) Can I use the newer one piece (inner sleeve / bushing / outer sleeve) bushings in my Gen 1 (1984 4x4) leaf springs? There are three types listed in the LMC catalog - one bushing set without inner sleeve, one bushing set with inner sleeve, and one set with "plastic frame shackle bushings". My truck has the front leaf spring bushings that appeared to be one piece, and the rear appeared to be two pieces with no sleeve - they just fell right out of the rear of the leaf spring when I took it off. Basically I need to know that the leaf spring bushing diameter is the same between all years, and the width the same.
2) I am trying to source U-bolts - I think the dimensions are 1/2" (bolt width) x 2 3/4" (inside bolt width) by 9" (bolt length) but wanted to check here. The problem is there is an aftermarket overload spring setup that I want to keep, and I want to get all the U-bolts at the same place. LMC wants $12 (I think) per U bolt / hardware. A little pricey in my mind.
Thanks in advance!
Thanks in advance!
