2.3L ('83-'97) Turbo swap fuel pump wiring
Countrykev26
Kentucky
Ranger xlt
I have an 85 t-bird turbo swapped in 93 ranger. Does anyone know if I can use Ranger fuel pump wire or run a new one from ECU to fuel pump. I’ve heard that the original Ranger wire makes the ECU run in high octane mode.
scotts90ranger
4,505
Dayton Oregon
2.3 Turbo
All you have to do is go to the ECM connector and pull out the wire, that's it, it's just a fuel pump power confirming wire to the computer, I think it's orange, I just taped it over and it's just in there, been like that for like 13 years now...
Countrykev26
Kentucky
Ranger xlt
Thanks, that’s what I did, but having flooding problems so I decided to change sensors, fuel regulator and plugs. Then it’s to the tps voltage adjustment.
scotts90ranger
4,505
Dayton Oregon
2.3 Turbo
Did you get the VAM wired right? I had one of those go out at one point and it ran like GARBAGE, had flames over the tailgate (straight back exhaust) which also got sooted up... unplugged it and was able to get home but limp mode wasn't good...
Countrykev26
Kentucky
Ranger xlt
I got Vam wired right. Check voltages and was good. KOEO no codes. I replaced ECT and gas filler neck and it runs terrible just with little black soot coming out tail pipe. Throttle response is bad. I got timing 10 BTDC. But ACT is broken off so I’m gonna replace it and see if that helps. I’m gonna do TPS adjustment after that
Countrykev26
Kentucky
Ranger xlt
It’s a 1993 ranger with a 94 wiring harness. It took me forever to figure it out. There were small differences in them so I used the diagram on here with 88-91 ranger and just matched it for 94. Brain racking I tell you, I couldn’t see straight after that. The guy before me had a mechanic work on it cause he had wiring issue. He butchered it. So it likes starting from scratch.
Countrykev26
Kentucky
Ranger xlt
Should I run with upstream O2 sensor or just plug it off. No cats and muffler. I plan on putting a muffler thou.
scotts90ranger
4,505
Dayton Oregon
2.3 Turbo
I'm running the upstream O2 on mine, are you using the Ranger sensor or the T bird? They're technically the same other than the T bird is likely 3 wire instead of 4 wire like yours had stock, the only difference is the heater ground wire, I had to add one since mine was a '89 harness set up for a 3 wire (fun fact, if you order a sensor for a '90 you get a 4 wire, title is '90 but was built in '89 so came with 3 wire...)
Countrykev26
Kentucky
Ranger xlt
Sorry to bother you but I flipped my exhaust manifold and so EGR needs either an extension tube or do I block it. We don’t have smog testing here or anything like that. What would you recommend.
scotts90ranger
4,505
Dayton Oregon
2.3 Turbo
I'd just plug it off, there's no feedback on the original turbo ECM's so they don't know. it's frowned upon but for non daily drivers...
