tube bumper vs plate
86MUDRCJ
8
Sheridan, CA
2.9
I have been thinking about what type I want I just haven't really decided. What are the pros and cons of each? I know tube is lighter but plate is stronger, but that's about all I know. Feel free to educate me because I kinda need to get the ball rolling. Thanks yall
crawlin91
60
Crawlorado
2.9, 4.0
Have you ever worked with tube before? do you own or have access to a tube bender, notcher etc.? The notching can be done with a lot of patience and an angle grinder/chop saw but the bending part is kind of hard to get around without the proper tools. Will this be a front or rear bumper, are you going to run a receiver on it? Do you ever plan on mounting a winch to this bumper? What design do you like best? These might be things to consider before you buy. HREW tube is a lot cheaper than DOM...it is not as strong but will work fine for a bumper. Figure out what you want, check the prices of stuff at your local steel yard and go from there.
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
Tube (both round or square/rect.) is going to be MUCH more rigid than plate or open c-channel type stuff of the same weight (unless you were to build it into a box shape with plate on 4 sides).
I built mine using 2x2" and 2x4" box tubing (2x5" I used for the rear). They actually came out a fair bit lighter than the stock bumpers were, yet are much sturdier (I think I have pics in the Bumpers Sticky thread up top here).
86MUDRCJ
8
Sheridan, CA
2.9
I have worked with tube and plate about the same, but i don't have all the tools to bend the tube. I do know a couple a people who have the stuff i don't so I can use theirs. As far as design i have liked both but i just cant find a design that incorporates both and looks decent. The rear bumper is going to have a receiver on it, and the front will have a winch on it and also lights wired up somewhere. Now, the price of each is pretty dang close since i know a guy that owns a steel yard and he gives me a pretty decent deal most of of the time.
