bodkin1
- Oct 7, 2007
- 0
- Age
- 39
- Carbondale, Illinois
- Ford
- Engine Size
- 4.0
Lately on one of the rangers down at where I work, on occasion when you try to start it up all it will do is crank and not turn over. Mind you, it only does it off and on. Other times it starts up normally.
One of the guys I work with discovered if you switch around the relays at the P.D box it will start right up. Bad fuel pump relay perhaps? Or something else. It only does this every so often, not all the time.
Truck is a '94 extended cab 4.0.
