Chris102371
- Feb 25, 2008
- Reaction score
- 0
- Location
- NC
- Make / Model
- Ford
- Engine Size
- 2.9
- Automatic
So I have been having the same issues as other people on here with there truck running rich and crappy. Runs good cold,but when it warms up and on the highway it will hit a flat spot and I have to push the gas further down to get it to respond and pick back up. I have been trying to diagnose this for several days now and I pulled the fuel pump fuse and the truck still stays running. Is there another power source I am overlooking? I pulled the atc sensor out and it was wet and smelled like gas. I was wandering if FPR was bad and sucking gas through the vac line. But I pulled the vac line off with it running and it kept running. Already checked TPS and it seems fine. coil is brand new msd street fire. Did TFI check sheet from tech section and it passed, also hall swith passed to. Pulled codes and got a 67,which is the safety neutral switch. Have to get one of those. Dist. cap and rotor are new.Any ideas would be great. Thanks.
