TRS Pun War
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
parallel leaf springs I presume?
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Would have to be. In series wouldn’t work.
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Don't be so negative
superj
2,578
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
i think he is just amped to be here
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
as long as he stays positive, he can take charge
Junk Collector
Truck of Month
4,802
Rapid City SD
Too much Surge can cause a brownout.
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
I wonder if we have the capacity to continue this, hopefully the end is faraday away
sgtsandman
Ham Radio Operator
12,651
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
As long as there isn’t too much static.
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
the first volt failed, so he had to RE-VOLT!
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
ah, so the secret is rechargeable. that should amp up the results
sgtsandman
Ham Radio Operator
12,651
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
This thread is such a drain on talent.
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
I heard @cbxer55 is looking for a Bolt,
you know,
... for his Lightning
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
I guess the situation is terminal, pull the plug
1990RangerinSK
1,312
Saskatchewan, Canada
@cbxer55 You have 24 hours from the post you were tagged in (not this one) to either pass or pun.
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
since the situation is terminal we must prepare for dielectric
