Transmission F150 vs Mustang for the 5.0? Performance
Proyecto_5.0
Mexico
Ranger XLT
hi, i'm new here .. i want to make an engine swap to my ranger 1998 3.0 2wd for a 5.0 explorer 1999 and i want a 5 speed manual transmission, which is better in performance the f150 or the mustang? Excuse me but use the google translator since my language is Spanish ... thank you very much for your support .. Greetings!
53671
don4331
1,352
Calgary, AB
5.3
Welcome:
The M5OD from the F-150 is an easier install as is it basically a bolt in; but it is a "truck" transmission, so doesn't like fast shifts. It also has lower gearing which isn't really needed in a street Ranger.
The T5 from a Mustang will require you to create a clutch sent up (not too difficult if you are mechanically inclined); as it is a "car" transmission, it shifts much better. Note: If you swap the tail housing from an S-10 T5, the shifter would be very close to the OEM Ranger position, the Mustang tail housing moves shifter right again the seat.
Where in Mexico? (I work with plants in many locations down there). Your Ranger isn't one of the crew cabs is it?
Proyecto_5.0
Mexico
Ranger XLT
Muchas gracias hermano ... soy del noroeste de México, mi guardabosques es una cabina regular flareside xlt, aprovechándolo, puedes usar el mismo alternador del explorador o tienes que dejar el guardabosques uno, ya que yo lee que usan diferentes amperios, saludos!
53683
Proyecto_5.0
Mexico
Ranger XLT
Welcome:
S-10 T5 ....What year?
don4331
1,352
Calgary, AB
5.3
I believe it is the '83-95 S-10s have the T-5. Those after '93 are "World class", but you want to use a Mustang T5 body to get the correct input shaft & better (stronger) gears.
My fleet of Rangers has blown so many alternators; I've never worried about Explorer versus Ranger models - as I've done 2 V-8 Rangers, for certain they had Explorer alternators.
Last time I was in Guadalajara, I was trying to get of the guys to sell me his crew cab but he wouldn't part with it.
Proyecto_5.0
Mexico
Ranger XLT
My ranger is 1998 from what I read, I will not have a problem with the speedometer, it is great news, my transmission will be a 1994 5EDHH V6 mustang .. so I have to look for an S10 V6 before 1993 .. is that correct? I wish the best performance, greetings!
Guadalajara = mariachis and tequila. =)
if some of us are very attached to our cars hehehe
53705
Proyecto_5.0
Mexico
Ranger XLT
and could use Racing Short Throw Quick Shifter?
jbeach3101
4
Illinois
302
flipped rear shackles
You can run the M5OD like i did in my 92. Just make sure you use the correct slave and master cylinder together. The M5 definitely gets the truck moving quicker but top speed is eh. what ratio is in your rear end now?
Proyecto_5.0
Mexico
Ranger XLT
I got a standard transmission from a 5.0 95 mustang, in fact I plan to use their clucht system, the differential I will use that of the donor explorer with a ratio of 3.73
