trans crossmember for a 5 spd manual from 5.0l into a 1987 ranger 2wd.
svtcards
137
Lyman maine
302
3'' front 4''back
I was wondering what people r using for a trans cross member for a 5 spd manual from a mustang 5.0l?looking to use a 5.0l from a 1987-95 mustang with a 5 spd.any help would be great.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
re position yours if necessary....sometimes they line out fine.
Bird76Mojo
1,265
IL
In my 1987 5.0 swap truck, with a new T5Z front shift/rear socket trans from Modern Driveline, I used my original Ranger 2.0 5spd crossmember. I used aluminum to "back" the holes and filled them with weld, ground it all smooth, and then drilled new holes where I needed them to be. It all bolts in like factory.
svtcards
137
Lyman maine
302
3'' front 4''back
good to know.i will be modifying my 2.3 crossmember then.thanx for all the info guys.very useful and helpful
