tranny swap, please confirm
pimtool
prosperity,SC
a4ld to mazda 5 speed
1990 s/c 2.9 a4ld 4x4 electric t case
5 speed came from 90 s/c 2.9 4x4 manual t case
From what I gathered in the tech library, This will bolt right in with no driveshaft changes necessary.
What I have from doner vehicle;
mazda 5 speed
computer
flywheel
starter
What I am getting new;
clutch kit= slave cylinder, throwout bearing, pilot bearing, pressure plate, clutch disc.
what I am getting from junk yard;
pedal assembly
mastercylinder
resevior (fluid holder thingie)
lines
If I can find them in excelent shape, if not I will go new.
shift boot
tranny hump plate, might just cut a hole in the one that is there.
Any 93 to 97 ranger should work except maybe the tranny hump plate?
Please tell me if this is correct or if there is something I am missing. Thank You.
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
They are a direct bolt in. Are you going to use the manual case? Is so you may have a time finding the double shifter boot assy.
pimtool
prosperity,SC
just the tranny, t case is toast.
Jspafford
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
So you will just have to pull the floor plate loose for the new shifter. It has 4 bolts holding it down. Will have to pull the carpet loose under the dash.
