Simple version
Remove tcase skidplate
Remove driveshafts
Remove speedo gear from tcase
Undo all electrical connecters from tcase and trans
Drain all fluids
Remove exhaust(trust me you really have too)
Remove tcase to trans bolts
Remove tcase
Support oil pan and trans
Remove trans x member
Remove shift linkage
Remove trans to engine bolts(for the two on top a box wrench works while sitting in your engine compartment and reaching behind the valve covers
For auto trans remove starter and rotate the plate to remove bolts inside
Remove transmission
That's all I can think of, buy the haynes or chiltons manual its worth the 20 bucks.
