torque converter wont lock
william1
3.slow
ok so I have a 98 ranger 3.0 4x4 with a 4r44e trans (I think) shortly after swapping motors my tc wont lock up when I get up to speed (55-60) some times it will lock right up but most of the time it will pop in and out till I get a over drive light flashing if I turn the key off then right back on it will lock right up I Am guessing that shutting the key off then back on resets the ecu letting it lock up but I'm no tranny specialist lol also I thank I might add that when I start it when its very cold the tc kinda wines .... my truck has 239,000 miles any Ideas??:icon_confused:
william1
3.slow
o and I just wanted to add that my transmission never slips of hesitates to take off even when pulling a trailer.
william1
3.slow
Well any body have a 5 speed for sale ??? so tired of this auto
danger94
i have the same problem and cant figure it out im tired of this a4ld im doing a 5 speed swap too
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
William it would be safe to say that you need a torque convertor. There is a clutch so to speak in the torque convertor that locks up via shaft from the transmission. Sounds like it is just plain wore out. Like you have been pulling a trailer without the O/D button turned off.
Where are you located? I have a 5 speed fresh rebuild but that is all I have. No flywheel or anything like that. And also 2wd or 4x4?
danger94
thats what the guy told me but that didnt fix my problem
william1
3.slow
sorry haven't been on here in a while I Am located in patoka IL about 1 hour from St. louse its a 4x4 3.0 and the tc being worn out makes sense because the tc actually came from a donor truck that had a lot of miles on it and with the other tc I never had this problem.
the reason i had to swap tc's is when i tried to put the new motor in I didn't get the tc all the way in and got stuck on the splines . so I got the front pump tc and input shaft from the donor trans , also the other trans was from a 2wd but had the same numbers on it so I went ahead and used it
I guess I should have stated this before.
