- Dec 19, 2014
- 2
- H-Town
- Ford
- Engine Size
- 2.3L/3.0L
- 2WD / 4WD
- 2WD
- My credo
- Semper Fi
Ever have a stupid check engine light come on and then have some yutz at the auto parts store go into a long schpeel on what the code is and what you can "BUY" to fix it?
How would you like to have MORE diagnostic tools in your hand than any of those dinglewaffles could even fathom? How about having it for LESS than $20?
https://play.google.com/store/apps/details?id=org.prowl.torque&hl=en
In conjunction with a $12 bluetooth OBDII module...you now can see in REAL TIME every sensor your car gets data from
http://www.fasttech.com/product/1042406-elm327-bluetooth-obd2-v15-car-diagnostic-tool
Just plug this into the OBDII port on your car (that odd looking plugin usually below the steering wheel in your car) get this app on your phone...go ahead and drop the $5~ for the PRO version...it has SOOOOO much more available to it than the free one...but for basic...the free does ALOT!
Connect w/ bluetooth to the adapter from your phone...and pow...instantly see if anything is either not working or working out of specification that is throwing the code.
Just though you techy folks might enjoy this if you didn't already know
See what your car is doing in realtime, get OBD fault codes, car performance, sensor data and more!
Torque is a vehicle / car performance / diagnostics tool and scanner that uses an OBD II Bluetooth adapter to connect to your OBD2 engine management / ECU
Layout your own dashboard with the widgets / gauges you want!
It can use the GPS to provide tracker logs with OBD engine logging so you can see what you were doing at any point in time
It can also show and reset a DTC / CEL / fault code like a scantool. Helps you fix your car and helps keep repair costs down!
Torque also features:
* Dyno / Dynomometer and Horsepower/HP & Torque
* Can read Transmission Temperatures (vehicle dependant)
* 0-60 speed timings - more accurate than just using plain old GPS - see how fast your car is (or truck )
* CO2 emissions readout
* Customisable dashboard & profiles
* Video your journey using the Track Recorder plugin with onscreen OBDII data overlay - a black box for your car/truck!
* Automatically send GPS tagged tweets directly to twitter (for example if you are going on a road trip)
* Massive fault code database for lookup of fault codes from different manufacturers
* Theme support (choose from different themes to change the look of your dashboard)
* Send logging information to web or email CSV/KML for analysis via excel / openoffice reader
* Heads up display / HUD mode for night time driving
* Compass (GPS Based) that won't suffer magnetic interference
* GPS Speedometer/Tracking and realtime web upload capability - see what you were doing and your engine, at a point in time
* Turbo boost feature for vehicles that support MAP and MAF sensors (VW & Golf / Audi / Seat etc supported)
* Alarms and warnings (for example if your coolant temperature goes over 120C whilst driving) with voice/speech overlay
* Car dock support
* Graph data
* MPG
* Able to share screenshots to Facebook, Twitter, Google+, Email, etc
* AIDL API for third party apps, A simple Telnet interface for developers to talk to the adapter, and an OBD scanner.
* Works on tablet devices like the Motorola Xoom, Dell Streak, Samsung Galaxy Tab and Nook
Works on any vehicle that uses the OBD 2 standard (most vehicles built after 2000, but can work for vehicles as far back as 1996) if in doubt check with your manufacturer first or look for 'OBD2' on written on a big white label in your engine bay
