Topless Alma needs some ice cream.
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
So my brother has an old Ranger. 1985. 4 banger 5 speed. He’s had it since Christ was a child. She’s about as weight reduced as she can get and still stay molecularly in one piece. Another feller accidentally dropped a tree on it. Feeling guilty the guy offered to repair it until he discovered how much was no longer there. ( Rust Belt Truck). He found this 85 Bronco II chop top and gifted it to my brother in place of repairing said rusted Ranger. So here it is. She didn’t run , wouldn’t roll, but somehow was dropped in the drive at my brothers house. Brother asked me to get her road worth so he can take the ball and chain out for ice cream. Ive worked on her a little bit this summer but not much. Somebody jacked this truck up. I decided its easier to work on it at my digs so today she came to the Bronco Ranch for a “freshening up”. Brother calls her Alma. I call her other things. I’m gonna record my progress on this thread. So if anybody’s out there, here goes nothing. Stay tuned.
19Walt93
4,501
Canaan,NH
351
3"
235/55R16
Just a suggesion, stop calling it a female name and maybe it'll stop being a pian in the ass.
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
I believe it was fall 2021 my brother got the truck. We wrestled her for an hour tryin to get her in the barn. Once we got the hood up and looked around she looked mostly complete. 2.8 with all the crap still on it. Tossed in a battery, tapped the key and oh my god a grinding noise from the starter. Took at look see and well there was no index ring between the engine and transmission. WTF. Pulled the starter and looked around underneath her. Grenaded U joint on the left from axle. Shattered transfer case. Drive shaft extended with longer bolts and nut with lug nut spacers. Rear axle u bolt spring mount plates are turned sideways, cutting into the rear tire. 6” suspension lift with overloads and blocks in the rear. 1 set of 2” blocks and a set of bump stops from maybe a Ranger. No shims. This is nuts.
Searched the inner webs and found an index ring. Removed the driveshaft and dropped shattered transfer case in the dirt. Removed all the bell housing bolts and pulled the transmission back enough to squeeze in the index ring. Back on goes the bell housing bolts. Top starter mounting bolt hole is stripped. 🤦🏻‍♂️ Cleaned up the hole and use a bolt and nut. Called it a day and ain’t touched her again till this summer. Did a “ will she run” and got her to fire up but wouldn’t idle and rough running. Starter sounds like crap. I hope it’s not the flywheel. Pulled the carb off and did a total rebuild. Bolted her back on and hit the key. Fired up and ran like a champ. Next, see if she will roll. I need a transfer case. ( Hello tree crushed rusted ranger). Bonus, the ranger transfer case is the same manual shift but also has the double cardone joint at the rear, needed for suspension lifted BIIs. Removed, drained, cleaned, installed. Even fancied up the shifter.
I find it’s easier to see where you been when it’s clean and in good repair. Time for a break.
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
She needed a bath before going in the barn. All the girls are out. Playin musical Broncos.
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
Borrowed the driveshaft off my BII as it has a 6” lift and installed it. She would move forward ok but did not wanna go in reverse. ???? Rocked her back and forth a few times and she started moving ok but the clutch was fading. Bleeding the clutch was futile. Between bleeding episodes the abused starter gave up the ghost. PO beat the hell out of it.
Looks new except for the hammered cover.
Tried the brakes and they were hard as a rock. Found the brake rod from peddle to booster was so rusted it wouldn’t move. Gonna need all new booster and master.
This is when I decided to bring her to the barn. Got her here alright. Loaded her on the trailer with a 4 wheeler and tow strap. Unloading was easy but because it was quiet with no 4 wheeler running I heard some disturbing sound. Crunch crunch crunch. Crap!!!! That sounds like rear diff gears. That explains why she didn’t wanna go in reverse. Door tag says 3.45 gears but I haven’t physically checked. Rusty ranger also has 3.45s so I think I can switch out axles but I don’t know if it’s a direct swap. I’ll have to take some measurements. BII has a different axle as one side is shorter than the other. I’ll have to investigate.
While she was still at brothers house I did a few smaller projects. She came with no keys. Column had been punched out and PO used a screwdriver to start it. I swapped out the rusty ranger key switch and both door locks. Still need to do the glove box lock. Also had a missing drivers door window glass and regulator assembly. Another swap from the ranger.
I think this catches us up to current conditions. She is waiting my attentions in the barn. Priorities?
I’m thinking I’ll go back to the starter. She need to start and run or everything else is futile. I plan on putting some shop rollers on her today so I don’t have to air up tires constantly. While she’s up I’ll spin that rear axle and confirm the grinding is in there. Stab a new starter on her and hope the PO and jacked up starter and missing ring didn’t ruin the flywheel gear. 🤞
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
Shop rollers. I hate airing tires. Tires are super swampers TSL XS. 29 x 10.5 x 15. I bought them new a dozen years ago. Girl friend at the time had to have them as she already moved the driver seat and took over my rig. Sexy but noisy and rough riding. ( the tires not the girl friend )
Still have good tread and no dry rot. Rims are Cragar soft eights. 15x8 with 4”backspacing. They have never been on the road just used as rollers indoors. This setup will rub on my stock 85 when turning on anything but completely flat terrain. They would rub my 89 with 2” body lift on a steep departure angle while turning.
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
Got the rollers on. Found my grinding noise was left rear brake had broken the auto adjuster cable and it was tumbling around in there. Aside from that the brakes look new. Even all the hardware.
Pulled a starter from my rig and put it in. Turned the key and had a good sounding starter and a great start. I was worried about the flywheel teeth. Let her run a few minutes and shut her down.
Want to move on to the clutch but I have no rear driveshaft and the front has a broke axle....... axle it is.
She didn’t put up much of a fight but I did use a big pry bar. Splines were not twisted. Stole the axle from the rusty ranger a few weeks ago knowing I would be needing one so I cleaned it up and put it back together. Spindle could use new bearing and seals but we will come back for those later.
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
Hello there,
It sounds like quite the story you have with your brother's old Ranger and the gifted Bronco II. The nostalgia and effort put into these vehicles are truly remarkable. Your determination to revive the Bronco II and get it roadworthy is commendable.
The truck had quite a journey, from being dropped off at your brother's place to now undergoing a "freshening up" at the Bronco Ranch. It's clear that you have a plan to document your progress on this project, and I'm sure there are fellow enthusiasts out there who would be eager to follow along.
It's heartening to see the dedication you have for these vehicles, despite the challenges and hurdles you're facing. Best of luck with your efforts, and I hope Alma gets the attention she deserves and hits the road again for those ice cream runs. Stay determined, and keep us posted on your journey!
Thanks for the encouraging words. As you can tell I have a few of these old rigs. I daily drive one and the others mostly keep the dust off the ground. They never fail to draw attention when I take them out for a drive.
I’m not a trained mechanic, just an old dude with a love for old trucks and a need to stay busy. My facilities are modest and my tools are limited but it’s all for a good time and honest personal rewards.
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
A couple days outside the barn cuz..... SQUIRREL!!!
Today I’m gonna get back to the clutch. I understand these are notorious for being difficult to bleed. The trans is a FM145. I have the same in 1 of my 85s but was originally an A4LD. I never had a clutch issue when I did the conversion. Never had to bleed it. Now this one here has already tried my patience but I’m gonna give it another try. First I’m gonna try and vacuum bleed from the res. We’ll see how it goes.
ekrampitzjr
1,094
Virginia
You ought to rename this BII "Lucky".
As in the old joke: "Looking for my missing dog. Has mange. Has only three legs, one ear, and one eye. Has been castrated. His name is Lucky." :LOL:
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
So that damn clutch is killin me. I’m convinced the master is bad. Leaking air from the peddle side. Anyway, trying to get the line off the slave. Pulled the pin but no joy. I think part of the pin broke off and is still holding the barb on the fitting. This is a FM145 with the grenade pin holding the line to the slave. A picture of the one I removed vs a picture of one I found in another thread.
Mine looks a bit shorter. No Es bueno. I think I’m gonna have to drop the transmission.
Pedal is still hooked up so I’ve got a board wedged against the seat holding the pedal down. Let it set overnight see if it pops loose. My hopefulness is waning
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
Upon further testing I don’t think there is any of the old pin in there. I can prob with a pick or drill bit and I can prob past the connection. Sooooo... crap. For fear of damaging something I think I’m gonna drop the transmission. Chances of it going smooth? I give it 50/50. I’ve had it loose to put on the index ring. Hope the y pipe come off. 🤦🏻‍♂️
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
As a testament to not giving up, I finally got the clutch line disconnected from the transmission. Removing the bleeder gave me a little more room to get on it with some lock pliers. I damaged the plastic hose but I have spare parts and can make one good set. Here it is ready to go in but sweet Moses it’s hot out there. 🥵 Break time in the A/C with a cold drink.
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
Master back in the truck. Bled it every conceivable way. Gravity, vacuum, forward, backward and upside down. I can get it to disengage the clutch once when I start it. It will go into gear if I keep clutch pedal in after I start. Put shifter in neutral and let off clutch, push it back in and it’s gone. I’m not leaking any fluid so I can’t figure out where the failure is.
I have now removed the transmission and it’s on a dolly in the middle of the barn. Pulled off the slave, it looks old. Says FoMoCo and USA. 🤔 does this mean it’s factree? New slave and master are on order so I hope to be reassembling later this week.
Spent a little time tinkering with small issues. When you turn the key to acc the dome and dash lights come on. 🤔 I don’t think it’s supposed to work that way. With key off, opening a door won’t turn the dome light on.🤔 No tail lights, emergency flashers work but turn signals don’t. Crazy stuff happens when people do their own installs. It’s easy to believe anybody would have enough common sense to do simple things like change a light bulb or use the same power source for their new radio as the old one used. Apparently I over estimate people’s intelligence. So the radio (not original) used the same power wires as the original however, they used all of them. Always powered ( for clock and memory), acc power and dash light power all twisted together for power source to radio. That’s why dash and dome lights come on when you turn key to acc. Got that mess all sorted. Then found turn signal, brake light tail light bulb(1157) in the right tail light was installed backwards. It’s not supposed to even fit in the socket that way but there it was. It was allowing power to draw from the wrong source bypassing the flasher. That and some wires crushed and melted under the rear bumper mount bracket was the cause for the lighting issues. Some one removed half the fuses most likely because they ran out after continued blowing. Got that mess all sorted and now have functioning lighting with the exception of no dash lights and no dome light with headlight switch. I have all the other exterior light so I believe the trouble is in the headlight switch itself. I will swap it out with a spare to confirm.
Spent some time getting the rear axle u bolt brackets turned to the correct orientation. Again common sense has left the job sight. Trimmed the u bolts enough to get a deep well socket on them. Got the bolts off and spun the plated 90 degrees. Whoever did this had to splay the bolts to fit in the bracket. You would think that would be a clue but 🤔 🤦🏻‍♂️ never mind
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
Alma update......
Finally got the correct slave and have put it on the trans and the trans on the engine. The new clutch master is a little different. It’s a cast metal piece not plastic. I think it’s aluminum. Nice. So it’s in and bled. I think I have a clutch but the firewall and floor are so weight reduced they won’t securely support the brake and clutch. I’ve tried talking my brother into giving up as she is so rusted but he doesn’t care. Just wants to bomb around on the farm and in the woods. Even if it’s never on the road again. So I will endeavor to persevere.
Here’s the firewall and floor.
It pushes away when you apply the clutch pedal or the brake. Short of tearing everything out and cutting bending welding ect ect ect. The only fix I can think of is support rods holding it. Pulled out some scrap steel and started fabricating. I’m making a back plate and two rods from the firewall to the radiator core support. They need to be removable and avoid interference with other equipment. Here’s what I got.
Parts are in the paint booth ( back yard on cardboard). I will post assemble when the dry.
