Top Speed of 60.. wtf help.
Brick+Truck=Good
21
Florida
FORD
4.0L 6 Cyl.
Okay, first things first, My buddy and I dropped the tranny, replaced the clutch set, the slave cylinder, and the fly wheel. Then the master cylinder.
all that said and done, I changed the intake with an aftermarket intake.still a cold air, just now it's a cone style cold air. I'm in florida, so this partially makes sense to me.
When I drive down the road, the max speed I can get to is 60. The engine runs rough. occasionally the check engine light comes on then turns off. The light isn't on for more than 2 seconds at a time.
cr_the_machinist
Dexter, Michigan
4.0L OHV
Grab a code reader and pull those codes. Even if the ecl is not illuminated, there can still be pending codes stored in your pcm. I would check out the MAF, in my opinion. Those codes will help you pin point the issue. I kinda had the same problem when I rebuilt the top end on my 4.0 and it ended up being an unplugged camshaft position sensor.
Brick+Truck=Good
21
Florida
FORD
4.0L 6 Cyl.
it's a 94, and i don't have a code reader for that :/
bilzy7
32
Lynn, MA
4.0 SOHC
brick+truck=60mphspeedlimit!
Brick+Truck=Good
21
Florida
FORD
4.0L 6 Cyl.
I'm fixing to add +lake to the equation.
