Tools, homemade and moded
Otis413
117
Cass, WVa
4.0 SOHC
Interested in what people do to make things easier, I like building my own stuff when I can, so I'm looking for winter projects.
The other day we decided hooking the engine hoist to the 3 point hitch on the old mini tractor would be easier than dragging it around on the gravel driveway.. EZ mod and I can always bolt the legs back on to use stand alone again.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I like how you officially and legally registered your truck for farm use... :icon_rofl:
ericbphoto
Overlander in development
16,741
Wellford, SC
3.0L
6"
There's already a thread like this around here somewhere and it has some awesome projects in it. I'll look and post the link.
Otis413
117
Cass, WVa
4.0 SOHC
Hey, anything worth doing is worth doing right... ;-)
But seriously, up until a couple of years ago as long as you had insurance the local LEOs didn't care, as long as you didn't travel too far from home. Recently they've started cracking down, Farm plates and all that..
ericbphoto
16,741
Wellford, SC
3.0L
6"
3,614
The other day I was asked by a co-worker if I was missing "half a wrench". I then had to go into an in-depth explanation for the new kid why I have a 25mm wrench that I cut in half.
The lower EGR tube nut on my Ranger is 25 mm. The full length wrench did not have enough room to swing at all, so I cut it in half. I then found that the box end is handy for the top of my brake clean sprayer, and tends to end up all over the shop.
ericbphoto
16,741
Wellford, SC
3.0L
6"
Doogie., nobody manufactures the "right tool".
Ultra-deep 15/16" socket
ericbphoto
16,741
Wellford, SC
3.0L
6"
I have several special home made tools. I had a pair of open end wrenches with about a 2 1/2" offset in the handles and extended handles for setting valve lash on Mercedes Om617 diesels. I let those go with the car when I sold it.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
TRS 25th Anniversary
12,789
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I have a modified ball joint c clamp tool from the Honda CR-V days. The u-joint cups were too small for the press pin. I had to grind it down so the pin would fit in the yoke.
19Walt93
4,498
Canaan,NH
351
3"
235/55R16
I have a home made tool that presses distributor gears off the shaft, a trailer dolly made out of an old snow blower base, a home made tool to compress the clutch pack springs in my C4, a small screwdriver with a short piece of tubing over the blade so I can tweak the carb adjustments on my chainsaw while it's running, and a bunch of ground or bent metric wrenches left over from replacing cam chain guides on those NFG Mazda/Couriers 40 years ago. Necessity is the mother of invention, not wanting to buy what I could make is the father. It's not being cheap, it's being frugal.
Roert42
5,030
Kintersville, PA
Ranger XLT
4.0 SOHC
About four years ago I was rebuilding the cooling system in my 4.9, so I build a low profile 52?mm wrench to get the fan clutch off. I made it out of a scrap stainless plate from work
It worked, but the shitty welder I had, the 6013, did not like the stainless. So the welds look like shit.
last summer I was rebuild the rear end on the same truck and I needed something to hold the pinion flange while torquing the pinion nut. So I drilled four holes in it to bolt it to the flange and welded some 1/8” flat stock from tractor supply to it to leverage.
51336
85_Ranger4x4
17,972
SW Iowa
View attachment 51326View attachment 51327
I have a similar thing for my A-C too
mikkelstuff
469
Brighton, CO
3.0L
This tool loosens/torques the rear lower right hand head bolt on a 460 in my '75 Ranchero without having to remove the A/C evaporator case.
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
Modifed 27mm (1+1/16") 12point DeepSocket
Depth\Length Shortened & DriveEnd Narrowed with BenchGrinder,
to ease replacement of OilPressurized TimingTensioners in a 2001 Ford V6~4.0L~SOHC Engine;
provded clearance between IntakeManifold & ThermoStatHousing, plus reduced interference with TensionerWasher.
51354
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
Modified OilFilter StrapWrench
Handle bent 90degrees for better clearance.
HingePins replaced with JamBolts+Nuts for using Socket+Extension+Ratchet.
Velcro added inside of strap for better grip.
Makes stubborn OilFilter removal easier in tight quarters.
51355
