jwreese
Missouri
2.9 for now
I have been reading the tech on tire/wheel size and fitment so I stopped at a friend's garage who does a lot of off roading and asked about tire size and he thought a 30x9/50 R15 would be about right on an 8.5 rim and should fit the BII w/o cutting or rubbing. Is that your alls experience?
Thanks Jim
cowboy
Cardwell, MO
'91 Explorer 4.0
I just put a set of 30x9.5/15's on my 89 b2 three days ago and have to say they fit like a glove with zero rubbing anywhere. I was worried going from the 235/75/15's to a larger size would rub on the swaybars but no problems so far. Good luck.
RangerBoy94
24
Northern California
360CDI
You can probably even fit 31/10.50's no problem.
jwreese
Missouri
2.9 for now
Thanks Guys.
The information helps alot. I am looking forward to getting the BII back to the way it was in the late 80s when I dove it more, all over Missouri and Arkansas.
Jim
Lpannell25
2.9L
which is cheaper 235/75/15 or the 30/9.5/15? the tire guy at the auto auctions cheapest was 4 good year wrangler a/t for 75 a piece... should i hold out or are decent off road tires gonna be cheapest around 80 or so?
jwreese
Missouri
2.9 for now
Would those tires be the same size?
Jim
Lpannell25
2.9L
correct me if im wrong but the 235 is fractions smaller then a 30? obviously depending on manufacturer but dont 235/75/15s run between like 29.5'' and 30''? but yeh with them both being so similar they basically are the same size which is why i was wondering if there is a price difference
Totalled
Law Enforcement
Tumwater, Wa
8 rabid gophers
an 8.5 wide rim is way to wide for a 30x9.50 tire. Try a 15x6 or 7.
Totalled
Law Enforcement
Tumwater, Wa
8 rabid gophers
If he lifted it or cut out the front fenders. It'll rub otherwise. 30/9.50s on stock wheels rubbed on mine stock height.
Rose2300
7
ID
Toyota
3.4
yeah 30x 9.5's are slightly larger than 235/75's. and yeah i wouldn't go bigger than a 7 inch rim, 8.5 inches seems too big. I ran 30x9.5's on a 15x7 and i wouldn't have wanted a wider rim.
kaytor692
ford bronco ll
i have 31/10.50 R15's on mine with stock suspenion and havent cut my fenders and they only rub a little
