Tire and Wheel Size????
bonedoc
Northeast,Pa
2.8L, durasparked, 350 holley, headers, 2 1/2 inch exhaust
Have an '85 Bronco II with a 4" rough country lift and 31/10.50/15 tires on 15x8 wheels.
Planning on installing a James Duff stage 3, 5 1/2" to 6" lift. Want to run 33" tires and was curious what rim size everyone would recommend, 15x8 or 15x10? Any answers or suggestions are appreciated.
Thanks!!
:icon_welder:Knows enough to be dangerous!!
holeshot
2.9
I would go with 15X10's. The wider rim will give you a wider footprint on the road, thus more stability. Once you get up there with the 6" lift, anything helps! Plus I think they look better. You might have to do some fender trimming though if you go with 15X10's. (I did).
Heres mine with a 6" Skyjacker. 33-12.50's on 15X10's
http://www.therangerstation.com/forums/showthread.php?p=578982#post578982
bonedoc
Northeast,Pa
Looks nice!! How does it handle? I have fender flares on mine so trimming will be interesting.
holeshot
2.9
Thanks! It handles surprisingly well. I put pretty stiff shocks on it though, so that could make a big difference.
You might get lucky and not have to trim any. I think when my lift was put on, we didnt locate the crossmember under the tranny all the way forward, so the axle centerline was off.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
If you'll be offroading it a lot, 15x8 will be better. 15x8s will retain the tire bead better when you air your tires down for a good trail (they also aren't as prone to getting damaged by rocks or knocking off the balancing weights because they allow the tire to stick out past the rim's edge a bit more).
