Tie rod end
FRENCHMan
FRANCE
Hello everyone
Sorry i don't understand
Search thread for
How to Replacing Tie Rod End a 1994 Ford Explorer or assistance would be welcome I believe there to step in tech library, thank you very much
You can also show a picture of the extraction tool
this
:icon_cheers::icon_cheers::icon_cheers:
chrwilkins30
6
Mishawaka, Indiana
2.9
try searching using a lot less words and that tool is a pickle fork. used to remove the tie rod from the steering knuckle.
1. First loosen the adjuster sleeve
2. Use the pickle fork to remove the tre
3. Once you get it off the knuckle then count the exposed threads for installation later.
4. Grab some channel locks and clamp it on the tie rod and remove it.
5. Then thread the new tie rod on and try and get the exposed threads the same as before for driving to the alignment shop
Just hit the ear of the knuckle with a 5 pound hammer. It should pop out after a few good shots.
chrwilkins30
6
Mishawaka, Indiana
2.9
That will work too. i had to rent the pickle fork because mine was just way to rusted solid.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
This gets er dun every time. Ball joints, tie rod ends you name it. A pickle fork is one tool I would never waste my money on.
FRENCHMan
FRANCE
:icon_thumby: Ok thank you very much for all for yours replys
90B24wd
Big Island Hawaii
Use two 5 lbs sledge. Place the second one on the other side to where you're hitting. This will lossen the tie rod faster.
FRENCHMan
FRANCE
:icon_thumby: Thank you very much for your reply.
that of the " arm pit " is very hard :damnit1:
bilzy7
32
Lynn, MA
4.0 SOHC
Whoa... Why would you want two? I used a basic hammer, 5 shots and it was out. I don't know why you'd need to or how you mean to use it.
I need to figure out wtf the differences is between a 45750 and whatever other number inner tie rod removal tool. Don't wanna get wrong kind. I see some are rounded at end. I believe those are for different vehicles completely.
TeamExploder
McClure, Pa.
FORD
4.0 OHV+SOHC
Well you have a 99 Ranger which has the rack pinion steering where as the Explorer he has, has a steering box setup. But my inner tie rod end removal tool is round, you can also remove them by turning the wheel the whole way to the side you are working on and get a pipe wrench on it to remove it.
FRENCHMan
FRANCE
:yahoo: THANK YOU ALL FOR YOUR HELP
In fact, they come out with some good shots well over the head with a hammer
:icon_hornsup::icon_cheers::icon_cheers:
