Testing for exhaust leak?
skinner
Louisville, KY
I'm actually hoping for an exhaust leak. I just got done building this motor, hooking it all up, only to hear a deep yet semi loud tap from one bank.
My first thought was exh manifold leak. But it's not a small one wherever it is(i've heard the ol pressure cooker hairline leaks). Its almost sounds like an old biplane. I'd hate(read:HATE) to tear this ***** back apart though to find out. I put my hand on the valve cover and didn't feel any knocking/tapping at all. I'm HOPING its the manifold or gasket(new gasket btw). Is there a good way to tell? Damn shops around here want 85$ and admittedly would just put a piece of hose on diff parts of the engine to try to tell where its coming from. I've done this, but its too hard to tell. And this isn't my first rodeo. Are there any shops that can do a UV gas test or something to the extent to let me know for sure?
Danger06Ranger
Lowell, IN
Ford/Mercury
4.0L/351M/2.5L
Smoke machine in the tail pipe always works.
Junk Collector
Truck of Month
4,858
Rapid City SD
Tried the wooden dowel trick? Seems to work better than a piece of hose for localizing noises.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Plug the tail pipe with a rag and feel around with your hands. It may just be the y-pipe leaking where it mates with the manifold, I just fiddled with mine for about an hour a bit ago to because it was leaking there.
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
The best bet is a tennis ball wrapped in a couple of shop rags.
have a friend hold it over the end of your tail pipe while you go looking for the hiss.
AD
lil red
Firefighter
Dirty Jersey
or spray a little carb cleaner in the carb or intake, and plug the exaust with a rag, itshould smoke like hell
projectnitemare
8
Osceola Mills, Pa
396W
AD
Thats what I use. You'll hear it leaking if there is a leak.
Matt
skinner
Louisville, KY
No luck guys.
Thanks for the advice. Rather than waste money testing it, I think im just going to pull one from a yard because they only want about 15 bucks and hope it goes away...can't beat that.
Anyone know if there is a difference between 2wd and 4wd manifolds on 3.0s?(its a 98 if that matters).
PaleBlue90
5
Aurora Colorado
FORD
2.3,2.9 and 4.0
im not trying to thread jack, but were mine meets the y-pipe its leaking. new exaust? or what?
