Temp gauge not working, but...
Spence2015
Davenport, FL
Mazda B3000
...I’m getting temp data fine from my OBDII reader. Also, ABS light and Check Gauge light keep coming on intermittently, but no codes are being generated, and my fuel level gauge is working, but squirrely. Could it just be that side of the cluster going bad? New member here.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
A. The temp data from the scanner is coming from the temperature SENSOR not the temperature SENDER. The sender only works the guage, the sensor feeds info to the computer. The entire gauge and sender can fail and the computer will still have a temp reading.
B. Most inexpensive scanners will not read ABS or vehicle specific codes so just because your scanner isn't picking them up doesn't mean they are not there.
C. Yes its possible the cluster has corrosion, loose ground, loose connection ect causing the gauges to not function.
Is there any actual driveability issues?
8,370
+1 ^^^^
Usually the SENDER is bad when temp gauge doesn't work
Picture of sender and sensor here: https://www.ranger-forums.com/attachments/general-technical-electrical-18/68679d1416398152-coolant-temp-sensor-issues-coolant-sensor.jpg
Sender has 1 wire, sensor has 2 wires
Sender is 12volts, sensor is 5volts so NOT the same
Check gauge light is most likely because temp gauge isn't showing temp
Check brake fluid level in Master it can turn on ABS light when low, also a Red Brake light
Do you have 2 wheel ABS(rear wheels only) or 4 wheel ABS(4WABS)?
Look in the engine bay, next to brake master cylinder, if you don't see this: https://www.ranger-forums.com/attachments/suspension-tech-36/35576d1330041880-2000-ranger-2-wheel-abs-4-wheel-abs-please-help-img00115-20110226-1819.jpg
Then you have 2WABS
Spence2015
Davenport, FL
Mazda B3000
Sorry for the late reply.
Yes it’s a super cheap scanner.
No, no perceivable driving issues (knock on wood).
When taking the cluster cowl off I found out it was cracked already so I didn’t dig any deeper into the cluster until I can order a replacement, because I don’t want it falling apart on me.
Spence2015
Davenport, FL
Mazda B3000
+1 ^^^^
Then you have 2WABS
Ok, definitely 2WABS
