TCC Solenoid A4LD
groovtubin
29
NC
Ford Bronco II
Anyone here change it out? I blv u gotta pull Valve body to get to it? Ive seen the 3-4 n OD solenoid are EASY ta get to.. Thank you! Ive got the CODE for it, plus gas mileage stinks! :(
ford4wd08
513
Alcoa, TN
2.8 V6
Yes, you have to pull the valve body. Make sure to get the updated solenoid with two holes in it. I found Ford NOS on ebay for ~$40. Works great.
groovtubin
29
NC
Ford Bronco II
Thank you so much!
lil_Blue_Ford
6,211
Butler, PA, USSA
4.9L
If you’re going to pull the valve body, I would highly recommend at least a shift kit (Transgo) if not the rest of the valve body mods. You will thank me later…
ford4wd08
513
Alcoa, TN
2.8 V6
I agreed on this, I did the Transgo kit, very simple if you take your time and lay out a clean work place.
It definitely makes a difference on how the A4LD performs.
lil_Blue_Ford
6,211
Butler, PA, USSA
4.9L
Yeah, it is a bit of an exercise in patience and cleanliness, but so worth it. My 92 went from typical sloppy A4LD shifts to crisp shifting and stomping on the gas from a stop would light up the tires… with an LS rear. I don’t think I’ve ever got an A4LD anything to light up the tires until I did that. Think I had even picked up a little mpg.
groovtubin
29
NC
Ford Bronco II
It has short time on a rebuild here locally, shifts perfectly smooth, Symptoms are i cant take off in OD at a standstill, BUT i can shift into OD manually at HWY..speed, Bt if you don't down shift at stopping ( just under 25mph) the TC is DIS-enaged, ALL else is puurrfect! The 89 code is only one puling up on the OBD meter test! Read it out at the Computer ( pin 22-37) it reads 64 ohms, i blv 20-30 is correct point?
lil_Blue_Ford
6,211
Butler, PA, USSA
4.9L
If the rebuild didn’t do a shift kit, I would still recommend it.
I don’t know enough offhand to say what exactly your problem is. I believe there is a thing on the tech pages that’s a whole service manual thing for the A4LD that I referenced a bunch working on mine
groovtubin
29
NC
Ford Bronco II
Oh i sure appreciate the response, i had a full blown thing done, everything hi performance, gotta oem tcc solenoid on way, ill report back when done! Thank you!
lil_Blue_Ford
6,211
Butler, PA, USSA
4.9L
Hope you got new gaskets, the valve body gaskets are not re-useable
groovtubin
29
NC
Ford Bronco II
