T5 cable swap
svtcards
137
Lyman maine
302
3'' front 4''back
I told them what I was doing with there external kit and what master I use going to use and they never mentioned about needing a bigger bore master to run that slave.i guess we LL see how it goes.also was size is bore on the f550?
2drxploder
436
usa
ranger
347
lower
235 on 15s
.75 I believe read the last 2 or 3 pages of junglejoes project thread, he and I were talking back n forth about clutch.
I gotta say the more I drive it, I get what he is saying about pedal engagement being low. Im interested to see if using stock master has an effect. Svtcards could you elaborate on your set-up? Truck n all
svtcards
137
Lyman maine
302
3'' front 4''back
It's a 1987 ranger 2wd std cab shortbed lowered 3" front 4" rear djm setup.donor car for v8 transplant is a 1995 mustang gt with a t5.7 o clock fork opening.im using Rick's rangers trans crossmember and engine mounting plates with v6 mounts.energy suspension trans mount.8.8 rear from a 1990 ranger. Stock clutch master cylinder 3/4" bore/.75" like mdl recommends.like I told jungleJoe I'm pretty sure ramcharger and fabworks are also using same master I'm using with success if I recall right.
svtcards
137
Lyman maine
302
3'' front 4''back
I contacted modern driveline again to verify that the 3/4 .75" bore would be good enough to run the external slave kit I purchased.he said that's perfect to run it without issues.i ll let u know how it goes I guess.
svtcards
137
Lyman maine
302
3'' front 4''back
Have truck up and running with mdl setup with external slave.clutch seems to release like b4 swap .i had a couple buddies of mine take it out they thought same thing.haven t driven it much though since finally worked on the bugs. won't know how well it works until next spring.
