CraigK
- Nov 17, 2007
- 2
- Ford
I've been having intermittent problems shifting from 2H into 4H in my 87 BII (AT w/electric push-button). I went out to get the vehicle into 4WD before the next snowstorm hits (a couple of hours) and couldn't get it to shift.
I quickly removed the shift motor ALMOST. All the bolts came off, the harness unclips, the magnetic sensor is loose, and the motor even comes off the case, EXCEPT for one thick greyish wire that goes into the transfer case right beside the magnetic sensor. It seems to have some sort of metal clip that goes through a hole and seems somewhat loose, but doesn't want to come out when pulled fairly hard, even with pliers. This @#$*%$*$! wire is the only thing keeping the shift motor assembly attached to the vehicle. (Likely need to clean the brushes?)
How do I get this wire off so I can take the shift motor into the garage and work on it? Do I just yank harder? I do not want to screw anything up.
As usual, any help appreciated.
CraigK
CraigK
