swapping 2.9 l wiyh 4cyl.
Hardcowboy1
Weldon CA 93283
Ford ranger
WOULD THAT CAUSE HESITATION AND LOSS OF POWER
Josh B
1,987
Oklahoma
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
OK. Just to double check, this is a DOHC in line four, NOT a DOHC 2.9 V6, correct?
... Just to double check, can you post a pic of your 2.9?
snoranger
Professional money waster
ASE Certified Tech
13,677
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
What kind of sick twisted individual needs 4 camshafts!!
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
A ricer like me??
Ok, after reading (and translating) this whole debacle here is where I think we are:
OP has an 86 2.9 auto 4x4 truck with a leaking vacuum modulator, and a 2.3L Lima engine with a 2wd M5OD hanging around.
There is no way to mix and match any of these powertrain assemblies into any working configuration other than the ones they are already in.
To fix your transmission fluid in the intake issue replace the vacuum modulator on the right rear corner of the transmission, like Floored said to do. As Sno pointed out they are dirt cheap, last one I got was about $20. A failed modulator will effect the 1/2 shift performance of your trans, which can mimic any number of drivability issues. Additionally, and I know this sounds crazy, but gas engines don't really love to run tranny fluid as fuel. They prefer gasoline, and so getting ATF into the intake can cause it's own set of issues, like fouled plugs, if you are sucking up enough. Also, automatics get fussy when they get low on fluid, and that can look like lots of different issues to the untrained observer.
To do your 4-cyl 4x4 swap you would need, at minimum, the output shaft and extension housing from a 4x4 M5OD, in addition to the parts that you already have. Then you would have to tear the transmission completely apart (This will require several unusual tools to be obtained or fabricated, and a shop press since the gears need to be pressed on and of the main shaft that you are replacing). Plus wiring and computers which you already seem to know about.
To put the 2.3 and 2wd trans in as they are now and drive away can be done, but you need the correct rear driveshaft, your existing one is meant to connect to the bolt-up style flange at the rear of a transfer case, and your 2wd trans is designed to accept a slip yoke.
Most of this information is already sprinkled through this thread, I'm just getting it all into one place.
If I could come up with a complete Cosworth 2.9 and the harness to run it one of my RBVs would be loosing it's 4.0.
rusty ol ranger
2.9 Mafia-Don
7,593
Michigan
177 CID
Also OP, not to mention if you did the swap you would be doing alot of work to go from 140hp/170ftlbs down to the limas 100hp/130 ftlbs.
Change the modulator valve, if its still having issues we'll be glad to help. The 2.9 is a pretty reliable, hearty motor that usually on fails after cracked heads due to an overheat.
Really, a 2.3 is a step backwards and fixing the current drivetrain is the best anf most cost effective option.
