Swap in progress
Windsor ranger
Michigan
I'm working on my 99 ranger had a 3.0 automatic....well I've pulled that out and shoehorned a 74' 351w with a 1980 aod trans everything is in factory mount but my driveshaft seems a little short I can only get a couple inches in trans is there anything I can do or will I need a new driveshaft?
Junglejoe
66
Columbia Missouri
6.0
You can run a driverahaft spacer on the rear-end, ran them on foxbodys with a blower no issue.
19Walt93
4,467
Canaan,NH
351
3"
235/55R16
I had a machine shop make me a driveshaft to my measurements.
smilinjack
34
rochester, mi
ford ranger
408C
2"
Always bite off more than you can chew!! :)
CCI Driveline, Inc. in Casco, MI. 48064 made mine. Really good work and way cheaper than other quotes I got! And fast too!
SenorNoob
569
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Possibly convert the front joint to double-cardan vs single u-joint? That should a few inches of length to the driveshaft.
