Stock suspension and tire upgrade
ricardo93
pacoima, ca.
2.3
I have a 2009 ranger xlt, and I was wondering if I would be able to put 33x12.5's on it with stock suspension?
gw33gp
Ham Radio Operator
544
Costa Mesa, CA
4.0 SOHC
33"
You can't do it without lifting or cutting. I run 33x10.5" tires and had to do some minor mods to clear at full turn. I also have a 1.5" torsion bar crank.
Mickey Bitsko
Pagosa Springs CO>
live everyday like your gonna die tomorrow
Do you notice a stiffer ride with t-crank ?
gw33gp
Ham Radio Operator
544
Costa Mesa, CA
4.0 SOHC
33"
I do not have a stiffer ride with the t-crank. The spring rate of the torsion bar is not changed by cranking it up. If it is cranked too much, it gets too close to the extension stops in the shocks and it can feel like a harsher ride when they hit the stops.
I just cranked mine up 1.5 inches and I rarely hit the extension stops on the shocks. I go by the ride height adjustment in the Ford repair manual. I adjust it to just slightly over the ride height for a new or rebuilt suspension. That ends up being about 1.5" higher than stock on my Ranger.
ricardo93
pacoima, ca.
2.3
Could I stuff some 31x9.5's under?
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
They should fit with a crank, but might rub a little on turns, and may hit the inner fender well on hard bumps. But normal driving should be fine.
