Stock ride height?
kpritchett70
farmington, mo
ranger
My 95 4x4 is sagging in the front, the left is worse than the right. The previous owner put f150 springs on the rear. My question is does anyone know stock ride height measurement. I'm thinking center of axel to either the fender well opening or the body line? I'm trying to figure out how much the back is lifted and the front is sagging. Any help would be greatly appreciated. Thanks in advance
kpritchett70
farmington, mo
ranger
Thank you for the info but I still don't see the measurement I'm needing
superj
2,714
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
that's funny, it doesn't how the front height. it shows angles but no height like the back shows from the bottom of the diff
dvdswan
2,909
Seattle, WA
Ranger XLT 2WD
Go to the link at the top.
kpritchett70
farmington, mo
ranger
I have been to that link many times but unless I'm missing something the information I'm looking for isn't in there
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,585
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I just looked in the tech library myself and didn't see ride height locations or specs. Unless I'm missing it too. We need to capture this info and add it.
I'm sure that info is in a factory service manual... not sure a Haynes manual would have it.
Hopefully someone will share that info from their factory manual.
kpritchett70
farmington, mo
ranger
I looked online in a factory nservice manual and still couldn't find it. And my Haynes manual doesn't even mention it. Hopeing someone with a stock truck will be nice enough to measure it for me.
2011Supercab
471
Washington
Toyota Tacoma
No one is going to have a 27 year old truck that still sits at factory ride height.
Uncle Gump
Token Old Guy
13,585
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
@97RangerXLT don't you have a set of factory manuals for your truck?
dvdswan
2,909
Seattle, WA
Ranger XLT 2WD
Also info for 4x4s.
97RangerXLT
4,013
Fishers, IN
2"
31"
I have a cd... that only works in a computer with Windows XP or lower. So for the last several years i ha e not had to use it but when i was running Windows 7 pro. I just spun up a win xp virtual machine when i needed it. Not sure if Win 10 can do that...
AJ
85_Ranger4x4
17,975
SW Iowa
Because when viewed in its entirety it is only showing the 2wd truck. The rear diff will be the lowest point, lower than 2wd i beams.
The "Ride Height" may help.
This (and more) is all in this:
lowspeedpursuit
155
DE
B2300
I can't find a "dimensions" section in the '94 body/chassis manual to save my life, but under "Suspension: Vehicle Lean Correction (Front)" the "example" ride heights (to top of wheel well) given are approx. 25+1/2" for 2wd and 29+3/4" for 4x4.
I'm also not sure if this is stupid, but given approach angle A=21.8* and front overhang=28.3", you can trig the other side of the triangle on the 2wd '92 as tan(21.8deg)*28.3 = 11.32", which should fall between the bumper and valence according to the diagram.
