Stock 95-97 ranger 4x4
JunkYardRanger
Orlando Fl
I am not sure where to post this question ..... can someone with a stock height with stock tire 95 - 97 ranger 4x4 tell me how far the bottom of the door is off the ground if u look in this pic u will see the measurement I want Thanks
UrbanRedneckKid
17
Cass Co, Missouri
I was about to make the same thread...
I think there will be 2 stock ride heights, maybe 4.(excl. 2wd)
Reg cab w/235 tire
Reg cab w/265 tire
Super cab w/ 235 tire
Super cab w/ 265 tire
JunkYardRanger
Orlando Fl
I need the height with a 235 -75 - 15
nate09
6
green bay, wi
ive got a stock 93 super cab. ground to the back corner of the door is 19" on 235's
JunkYardRanger
Orlando Fl
thank you ... I was just trying to figure out how much over stock I am including tires
JunkYardRanger
Orlando Fl
After doing some measurements and a little math, I cam up with 21 inches of lift and 28 inches over stock with my 44's under it
