Stick shift 3.0 eating fuel
Nightbiker07
6
I have a stick shift ranger 3.0, it is eating fuel.
15 MPG or less. Used to get about 25 plus depending on driving habits and city/highway.
Stock tire size, no check engine light. Runs Great. Engine is tight, no ticks knocks or anything.
Stock exhaust.
Truck drives straight as an arrow, no abnormal tire wear.
Absolutely no idea where to start looking for the problem.
MikeG
752
central Texas
B4000
2"
235/75r15
Fuel pressure regulator would be my first guess, if you've done normal tune-up stuff.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,515
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Somebody stealing your fuel?
10 mpg is a big hit... you live in a cold climate?
Rearanger
23
Southeast USA
If you have access to scanner check fuel trims, but if no, start, idle or run issues then doubt you'll find it there.
Theft as Uncle Gump says, or fuel system leak. I don't think you have a vacuum fuel pressure regulator but you should have a fuel pulse dampener on the fuel rail. I would think if that was leaking you'd smell fuel.
8,372
You are either leaking fuel or burning it
Pull a few spark plugs and look at the tips, if they are dark brown or blackish then you are burning it
O2 sensors need to be replaced every 150k miles or 12 years, period, they run out of chemicals
Nightbiker07
6
Definitely not leaking.
Fuel rail is a dampener, not a regulator. I am very familiar with return vs returnless fuel systems.
I own a Genisys Evo scanner, used for daily wrenching, no I'm not your average moron 😅
I switched to copper plugs years ago because it cures the spark knock that the 3.0 is famous for. Only drawback is that you have to change them every 20,000 mi, so I'm pretty on top of what the plugs look like.
Just ordered new plugs, which the coppers are getting harder to find that fit the 3.0. 2 different plugs are discontinued that I used to use, won't be long and nothing will be available.
They are about halfway through their life cycle, so changing them won't be a complete waste.
Yes, I live in a cold winter climate, but this extended into the warm season as well.
I ran out of ideas, so here I am 🙂
8,372
Check the damper vacuum hose for gasoline, that hose is there in case damper leaks, so fuel is sucked into engine instead of dripping on engine or exhaust
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
650
Central Indiana
Brake dragging?
Blindmullet
7
Florida
How many miles since a cam synchronizer swap?
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Ever notice how many "my fuel mileage sucks" threads pop up during the winter. :unsure:
MikeG
752
central Texas
B4000
2"
235/75r15
Yeah. Run two or three tanks of no-ethanol gas through it (if it can be found in the area) and see what happens.
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
Marinas always have non-ethanol gas. Boats is no likes ethanol...
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
Boats go vroom?
Nightbiker07
6
Then you don't need help from us, "average morons" working for free. Good luck.
I probably could have worded that better, what I mean is that I've seen people do some really dumb stuff, and then come onto a forum asking really dumb questions that are painfully obvious.
That is a very real possibility I haven't considered.
Brake dragging?
I briefly did over the summer, bad parking brake cable. I replaced both cables and all the hardware, and did the fronts shortly after.
New parts are junk half the time, so I jacked up each corner, everything spins freely.
Have never replaced it, but I do keep an eye on it, as they are known to seize and then your oil pump stops. I have a few spare known good sensors I could swap out to test.
This problem has persisted since July, it's not weather related.
There are several stations that sell ethanol free rec fuel around here. It's all I run in my yard equipment. Everything starts so much better since switching.
I'll fun a few tanks through the truck and see what happens.
