Starter pinion not disengaging.
IceBergeRanger12
Tukwila, Wa
Ford Ranger XLT
Hey there.
Have a 1992 4.0L that's been having some starter issues. First problem I had was the truck started up fine but heard a clanking kind of noise coming from underneath. Shut off the ignition and the starter kept cranking. Turned ignition back on and was attempting to get it home and the clanking finally stopped while it was running. Starter disengaged finally. Got it home, shut it off and after that the starter would not spin. Starter relay still clicked on the fender wall but not juice. So figured I needed a new starter. Got a new one installed with a new relay just to be safe and the truck fires right up, however there's still that same clinking sound while it's running like the starter pinion isn't disengaged while the engine is running.
Don't see any adjustments that can really be made to how the starter sits and the flywheel teeth still look good. So is there some wiring that I can't think of that could be effecting that or does anyone just think I got a lemon of a new starter that won't retract it's gear?
Thanks
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Are the flywheel teeth damaged? There are shims for starters on some blocks, but I'm not sure about the 4.0L.
8,372
Start the engine then unplug the smaller red/blue wire on the Starter relay's "S" terminal, on inner fender and see if the clicking stops
Test it to see if it shows any voltage, should be 0 volts except when trying to start engine
Red/blue wire is from ignition switch, has 12volt ONLY when key is turned to START
Could be shorted to another 12volt full time wire, so has just enough voltage to cause the clicking issue
Manual trans has a Clutch switch on the pedal, but don't think there are any 12v wires on that 6 pin connector
Ignition switch has lots of 12v key on wires, lol
Stater motor has the small cylinder on the top, thats the solenoid that pulls the starter gear out to engage flywheel
Its spring loaded so without 12volts gear is pulled back
There is a smaller terminal on this solenoid, also "S" terminal, when that has 12v solenoid pulls starter gear out and ALSO activates starter motor AFTER gear is out all the way, so its dual purpose, a solenoid/relay
1992 should have that setup
The clicking may be because that "S" post is getting voltage leaked to it, should be 0 volts except when starting, voltage comes from starter relay on inner fender
On newer vehicles that red/blue wire runs directly to the starter motor solenoid
Old starters didn't have the solenoid, no cylinder on the top, just used a Bendix or similar spring drive to push out starter gear and retract it
IceBergeRanger12
Tukwila, Wa
Ford Ranger XLT
Don't see a red/blue wire. Relay only clicks when it should. My guess is the old starter mounted solenoid quit and never disengaged the old start motor. New one doesn't seem to have that problem but the spring loaded gear may not be retracting when rpms come up at idle? My guess is it's a lemon starter with a bad gear spring but was wondering if anyone else had any thoughts.
8,372
If you want to pull out the starter you can test that
Just ground the starter and apply 12v to the "S" post, you will see the gear go out and come back all the way when you remove the 12v, starter won't spin
If it's not retracting you will see that
IceBergeRanger12
Tukwila, Wa
Ford Ranger XLT
Update!
AutoZone sold me the wrong starter. They gave me the one for the Automatic and not the manual. No damage to my truck but deffinetly frustrating and I'll be sure to ask about that detail in the future when getting parts. For what ever reason the AutoZone guy blew by that question when I bought mine to start with.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,513
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Sadly... that is pretty typical service these days at the big chain stores.
I usually do my research and ask for a certain part number or order online.
IceBergeRanger12
Tukwila, Wa
Ford Ranger XLT
Yeah, that's deffinetly what I will keep top of mind. Ended up giving me a 20% discount for all the trouble but still lots of wasted time.
