square driveshafts
86ford
rocky river ohio
FORD
4.0, abused and misunderstood
i am thinking about making a square driveshaft for the front of the B2. which t-case would work best with a square shaft (1354/1350) i am wondering how much abuse the slip yoke on my 1350 with take with a square shaft up front. the only reason i am looking into this is because i am swapping in a d35 and dont want to spend the money to have a shop do the work.
86
Dishtowel
August OTOTM Winner
Grande Prairie , Alberta, Canada
i have heard of guys do it with success, but.... not for me thanks.
Really? it's not that much. 1 hr labour charge to shorten.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
If you get a 1354 you wont have to shorten your if you use the 1354 shaft, you can also use an FM145 shaft with the 1350 or get yours shortened for $75.
kunar
131
Toledo, Ohio
5.8l
i have always wondered that. i have an extra front shaft for an fm145, now i know i can use it.
86ford
rocky river ohio
FORD
interesting. i have 2 1354Es at my disposal, the 1350E thats in it and a 1350M. i also have a exploder front shaft. so you say it will work huh.....
86
projectnitemare
8
Osceola Mills, Pa
396W
If you are going to bother making a square shaft why not just make it with a tube. It's not anymore difficult. It's not that expensive to have a shaft modified by a shop either. Any yes you can use the shafts listed above as well.
Matt
Rulebreaker
5
Manton,MI
86
It's not the T case it's the tranny. A FM145 is shorter than an FM146 thus a FM145 front shaft would be shorter than a FM146 shaft. But if you lift the truck 5-6" when you change over to the D35 the stock shaft will work. But only for a while because you will put bigger tires on and then be thinking doubler! RB
