Need a little help.
I worked on my truck again some today. Since i don't know what's going on with the spout connector, i'll just assume that the plug near the radiator with the pink wires is it, and it is definitely removed.
I got the distributor positioned with #1 almost dead center with the engine at 0, and it will run, but it doesn't run strong or smooth and it eventually stalls. It sounds kinda like an old tractor with just the y pipe for exhaust. I might also try replacing the fuel filter and putting some good fuel in it (i have no idea how old the fuel is that is in it now). i've tried rotating the distributor a little at a time both ways and haven't had much luck getting it to run any better. If i rotate it counter clockwise, it revs up really fast when i start it, but dies right away. If i turn it clockwise, i need to have my foot on the pedal to keep it running. i need it to stay running well enough to hook my timing light up to it and set it where it needs to be (book says 10*).
i'm beginning to think that it needs to have backpressure from the exhaust system before it can be timed. Today i started grinding apart the nasty welds someone applied to the exhaust system that looks like it was pieced together from scrap exhaust tubing. i think i can salvage the cat so i can get a bolt-on factory style intermediate pipe. I bought a cheap muffler, and it looks like the tailpipe is intact enough to reuse. The old muffler was rotted through. At one time it was welded to the pipe, but all i had to to is give it a good whack, and the whole thing fell off. Also, it seems that the only support the exhaust had previously was the y pipe and the rear axle. All of the hangers are rotted off.
i also pulled My Idle Air Control Solenoid and noticed it was pretty gummed up. i had my wife turn the key to the on position, and i noticed that it vibrates slightly and makes a little noise, but i don't see the valve open and close. If i remember right from the other Fords i've owned, it is supposed to move a little bit when you turn the key. How do you test these to make sure they are good?
