Some questions about skid plates.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
TRS 25th Anniversary
12,810
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Ah, the shock mounts are just about as low as the differential so it kind of makes sense. On mine anyway, and, I'd wondered about that exposure.
I don't think you have to be specifically rock crawling to need protection (leaving aside for what). It can often be the case that you are on a back road / fire road and there are rocks, could even be pointy, sticking up, they can be part of the bedrock so stuck there and if there is no way around it you have to go over it. Or turn around and go home.
It's really a matter of inches. Say you pick a good path and you clear the rock by 1/4". All is fine. Say you don't clear it by 3/4". You will hit/scrape something. If you're off by 2", I'd say you probably will be hung up.
Where you'd hit, say, a fuel tank skid pate, is way above where you'd hit the differential, so you're trying to choose a path that works, of course, but depending on the surface (slippery?), you can move off your intended path.
Granted I'm probably the most inexperienced off-roader here, but it's geometry, you look at the underside of the truck and try to keep in your head what that looks like, then choose what path doesn't hit anything. I think this is where experience comes in, because you're not getting out and measuring outcrops with a ruler.
There are three possible situations: one, there's no visible issue, so no problem, two, there's a massive issue, clearly not passable with the vehicle. Those are easy decisions. The third situation is when it's probably/maybe ok if you take the right path/approach and the truck stays on that line, and those are the hard ones to know what to do especially for an inexperienced person.
I'll gain probably 1-1/2" height just by putting on new correct size tires. It doesn't sound like much, but it's a lot. Would 6" be better, sure, but dealing with what I have, I'd want to maximize height insofar as I can without making other changes at least right now.
Yes but the shock mounts are pretty close to the tires. While not impossible to hit them on something, the chances are minimal. Thus the rock crawling comment. There is always the possibility of having a rock problem on a dirt trail but I think the chances are less likely. Like you said, keeping the underside of the truck in mind and choosing your line plays a big part.
Josh B
1,988
Oklahoma
I found a road sign for mine :D
It's only a little thicker than a 1/16" like maybe 5/64
Robertmangrum.rm
Wannabe Overlander
1,643
Tennessee
2.3 EcoBoost
2.5 level kit with rear add a leaf appox. 1.5
305/70r17
Buy it, build it, and drive it like you stole it
I've read elsewhere that the diff skidplate for a Jeep Gladiator will work since they use the same rear axle.
Also someone makes little tiny skidplates for the rear lower shock mounts.
Yes the Rough Country diff skid works on the new Rangers. They are also the ones that make the shock mount skids. You do have to order them for the Jeep. The web site says they won't fit but my buddy Brian has been running them on his 19 FX4 for a while now. And he beats the crap out of them. He carries sponsorship so he has to go out wheeling or showing about every other weekend.
