Should i put anti-seize on my belt tensioner bolt?
modelageek
14
Boston, MA
TIA!
black_demon69
142
AZ
4.0l
why wouldn't you. won't hurt either way
FritzTKatt
4
Ohio
Depends if you want to spend 30 seconds putting anti sieze on it, or spend 20 minutes fighting it next time...
modelageek
14
Boston, MA
black_demon69
142
AZ
4.0l
Is that one of those trick questions? :)
Thanks anti-seize it is!!
if it comes off my truck it gets anti seize when it goes back on.
i also use on the contact points between bushings and the metal (cuts down on suspension squeeks..
i don't use it on any bolts on the drive shaft those get locktite..
modelageek
14
Boston, MA
Thanks for da feedback. I replaced the tensioner, put AS on the bolt and the chirp is gone!
--weezl--
June 2011 OTOTM Winner
Law Enforcement
182
hell
nice, i'm lazy so i often break the rules, but my rule of thumb is every bolt gets either antiseize or loctite!
drive shafts being one of the only ones needing loctite...
modelageek
14
Boston, MA
What about caliper bracket bolts?
black_demon69
142
AZ
4.0l
--weezl--
Law Enforcement
182
hell
caliper bolts, anti-seize, bracket, loctite, but like I said, i break rules, and I think what you're looking for is clarification on the "one of the only" portion of that post... there's a few, driveshaft bolts being one of the few
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I don't locktite fawk all. Just proper torque. Antiseize or a spray of honey goo on most fasteners as I assemble stuff.
Sent from my SGH-I747M using Tapatalk
--weezl--
Law Enforcement
182
hell
I think the only thing I have ever actually put loctite on, on my truck, were the body bolts, when I did my BL... I replaced a caliper bolt, but the new one came with loctite on it already
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
I use rust to make them stick and my engine oils everything else...only thing I use anti-seize on is my dipstick...you don't want some woman trapping you in a lip lock...
