Shift lever on 4r70w
4
Working on a 5.0 swap in 99 Ranger 2wd, trying to use a 99 Mustang v6 4R70W and just discovered that the shift lever is different. Does anyone have good source for another lever? I can probably adapt the lever from the old 4r44 but I don't have any reference point to clock it, anyone have picture of an Explorer lever in park so I can judge where to clock it?
Andrew.V
21
Manitoba Canada
2008 fx4 1988
4.0 5.0
Hi so if my memory is correct pull the pan off and you undo 3 bolts and a nut then you can flip the lever not 100% been about 2 years sense I did my 99 also check your bracket that bolts to the bellhousing that the cable slides into ran into that not letting my cable reach all the way. hope that helps.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
The pin ..
Andrew.V
21
Manitoba Canada
2008 fx4 1988
4.0 5.0
Yes completely forgot the roll pin my bad
