Seat swap
HVAC_Rat
Searcy, AR
2.9
Will the seats from a sport trac fit in the '89 bronco II?
3,614
Do you have a tap set? They are gonna have to go on your existing seat tracks and you might have to drill and tap some holes, but they can be made to work if you try hard enough.
BabyBronco89
GR Michigan
95' 4.0 OHV
i had a similar question regarding the new 02ish explorer sport two doors, i remember reading some where that the back folding seats of the 91-92 models would swap in, but these look similar and are a really nice grey leather, they fold down in the same manner as my 89 b2 seats
TexCaliBII
4
Palmdale, California
Neagtive for the rear seats
as a bolt in swap anyway. I put a set from a 92 Sport in my 87. The front seats dropped right in, no changing rails, mounts nothing. The rear seats are another matter. They are aller and just a tad wider than the BII ones but I liked they way they looked so I grabbed them and then proceeded to make them fit. I never took pics back then when I was doing this and I most likely won't do it again. The seat belts ount diffently and the seat mouns are different. I had to cut and turn the seat mounts to line up correctly for the BII floor. I brieffly thought about going back and cutting out the Sports's back floor... I had to drill new holes through the floor and created a nut plate mount from 1/4 plate and a couple nuts. Once I'm back on my feet, and if you guys care to see, I'll get some pics of how they are mounted and look in my rig.
