- Jan 3, 2009
- 11
- Salem, OR
- Ford
- Engine Size
- 2.3
It occurred to me last night that I've spent $1000 on my d35 and I still need shocks, coils, a steering setup, and build some radius arm mounts. I was kinda thinking why not just put a solid axle under it? I just don't see any reasons why I shouldn't? The costs will be about the same.
The two axles I am considering are;
-1976-1977 Early Bronco Dana 44. Its about the same width but its a low pinion/standard cut and it has 260x u-joints (small!)
-1976-1977 Ford F-150 Dana 44. Its wider than the eb d44, but it has bigger u joints and is a high pinion/reverse cut.
So, should I go for it? And which axle would you pick and why?
(Forgot to mention I will be running 35's with 5.13's)
