Safe to Run Engine with Driveshaft Removed?
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Whatever you do, it's going to make a mess. Been there, done that. When I did it the mess wasn't too bad, a bunch of oil speckles all over the frame and the floorboard underneath.
That’s called rust-proofing.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
If I need to run it in place, I usually just get the tires off the ground on some very sturdy jack stands and chock up the other end real god.
franklin2
1,758
Virginia
He has no driveshaft.
racsan
4,442
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
I twisted the driveshaft on a 85 jeep cj-7 once. (manual trans, 258-6) I removed it, locked the hubs & drove it as a front-drive that way for about 2 weeks. only issue was on tight turns because of the knuckle u-joints binding.
alwaysFlOoReD
5,094
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I would still bag the end to prevent dust getting in.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
