RUST, inner fender, under the hood...
fixizin
FoMoCo is forcing me to buy a 'yota
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
... right rear corner, near the blower motor, wondering if this is a "Florida thing", i.e. humid air condensing due to icy A/C air moving nearby?...
>>> Can I access the backside of this from the wheel wells if I remove the fender skirts? Figured I'd grind/nibble it out, hit the surrounding areas with Dupli-Color Rust Fix ("turns rust to black primer"), and patch with plastic screen + epoxy putty (PC-7 is my fave)... suggestions???
Thanks in advance.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Hehehehe.....
That's better then anything from Michigan.
Will be hacking mine all out this year.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
That's not bad. It's the firewall seam....torque box for the hinge mounts and the A pillar base with the windshield that is a pia.
fixizin
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
Where might rain be leaking in? Could this be related to beaucoup leaves trapped in the "cowl"?
Note the ground-strap, connecting Aluminum hood to Steel body... because when running E85, she gets up to trans-sonic speeds, and the static buildup is intense!... lol...
